Latest: Stu-mill
Overall: 17131
Online Now [434]:
Visitors: 433
Today: 7649
Total: 104693296
Forums › The Car › 206 Problems › 206 1.1 Sport P1340 code help
lea7784
PostPosted: Mon Jul 28, 2014 9:52 am Up
Hi guys having some trouble with my car the Engine managment light came on so tested it and it threw up the code
-P1340 camshaft/crankshaft sensor /power train control module
Its a 1.1 sport (special edition)
Its 2005 reg
What happened was it juddered just b4 the light came on but also lost power when changing down a gear when coming to a junction -started right back up again
I am having trouble locating the camshaft sensor for this model and have read somewhere that it doesnt have one (arghhh) not sure how true this is
any help advice at all would be fantastic
Shadowstalke
PostPosted: Mon Jul 28, 2014 11:42 am Up
Welcome to Peugeot (and for that matter, most Marques) fault codes. Just because it -says- it's one thing that's the problem, doesn't mean to say that thing is actually causing the problem!
A little googling shows that P1340 on a Citroen (another PSA car) is P1340 Camshaft position sensor B circuit Malfunction. This has been fixed elsewhere on t'internet by checking the wiring to the sensor. However, some code readers lump multiple errors onto one "code" so from your post, it's a Cam or Crank sensor issue, or the PCM.
If your engine has no camshaft sensor it will be the crankshaft sensor - try removing the speed sensor (points at the flywheel) and give the end a clean, check the wire looks ok etc. then give it a go. (Good Diagram in snailer's post here: www.206info.co.uk/Foru...1090.html)
Failing that, the other thing listed against P1340 in your error code is Power Train Control - this usually translates to an ECU error (I don't think the 206 has a specific Transmission Control unit - anyone?). If this is the case, that's a whole new kettle of fish... (http://www.206info.co.uk/Forums/viewtopic/t=44369/view=previous.html)
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
lea7784
PostPosted: Mon Jul 28, 2014 11:53 am Up
Thanks so much for the reply I will deffo give the cleaning a try first off Smile
Shadowstalke
PostPosted: Tue Jul 29, 2014 6:15 am Up
No worries Smile we'll all be in the same boat at some point!
No Smoke, No Poke!
lea7784
PostPosted: Sun Sep 21, 2014 4:19 pm Up
Ok so ive just had the crankshaft sensor changed and its no different however I really cant find the camshaft sensor at all
can anyone out there help me please?
PostPosted: Mon Sep 22, 2014 3:30 am Up
Some cam sensors are under the cam cover. Not sure about the 206 1.1 Someone will be along soon to help.
badj
PostPosted: Mon Sep 22, 2014 5:00 am Up
As Shadowstalke said, there isn't a camshaft sensor.
Iceland Blue '99 206 GTI (140) - SOLD
KMF '05 1.4 HDi
lea7784
PostPosted: Mon Sep 22, 2014 8:40 am Up
Someone else online had said it didnt have one lol Well thats me cream crackered only other thing I can check
lea7784
PostPosted: Tue Sep 23, 2014 9:11 am Up
Changed the Coil pack today didnt have anything to lose and so far (touching all kinds of wood ) seems like a different car
