Latest: tbafonso
Overall: 17130
Online Now [148]:
Visitors: 147
Today: 52622
Total: 103788375
Forums › The Car › 206 Problems › can,t find air mass meter on GT
cat41
PostPosted: Mon Nov 24, 2014 8:49 am Up
Hi guys,i,m in the process of changing the airbox for a cold ram air feed but i,m not sure where the air mass meter is, wantvto findbit before the bew air feed turns up.
Its a gti engine, 1999 petrol 138 bhp.
PostPosted: Mon Nov 24, 2014 11:51 am Up
You won't find one...
cat41
PostPosted: Mon Nov 24, 2014 11:54 am Up
Cool makes life more easier.
PostPosted: Mon Nov 24, 2014 12:03 pm Up
It uses map sensor and throttle position sensor to measure engine load.
PostPosted: Mon Nov 24, 2014 1:14 pm Up
I agree! What He Said
PostPosted: Fri Nov 28, 2014 4:05 am Up
Airmass meter is for diesel.
MAP + MAT + TPS or MAP(T) + TPS is for petrol.
