Latest: tc.206
Overall: 17147
Online Now [55]:
Visitors: 54
Today: 1878
Total: 116544378
Forums › The Car › 206 Problems › fuel pomp is ok but not wirking
mrsep
PostPosted: Thu Nov 27, 2014 12:59 pm Up
hi.i have 206 1.4. from this morning the car start but wount go throgh.i cheked the fuel pomp its not working.but when i connect it directly to battery it works.then i chek the sucket which is connect to the pomp it has electericity .so evrithing is ok but the dont like to coaprate with each other
PostPosted: Thu Nov 27, 2014 4:01 pm Up
Struggling to read your post, but it might be a blown fuse or bad wiring.
mrsep
PostPosted: Thu Nov 27, 2014 8:55 pm Up
can u tell me were is the fuse fo that?
PostPosted: Fri Nov 28, 2014 5:49 pm Up
check this out.
Leegsi
PostPosted: Sat Nov 29, 2014 9:24 am Up
Do you have a fuel pump cut of switch in the engine bay?
