Online Now [61]:
Visitors: 60
Today: 80249
Total: 105974183
Forums › The Car › 206 Problems › Name this part?
Name this part?
NiGHTS
PostPosted: Tue Dec 16, 2014 6:23 pm Up
Hey Fella's
I need to replace this air line on the top of the engine with the yellow clip as it's become brittle and now cracked. Here is a pic of what I mean:
onedrive.live.com/redi...hoto%2cjpg
Does anyone know the name of it or a part number? Where is the best place to get one?
Cheers.
gazza82
PostPosted: Wed Dec 17, 2014 5:05 am Up
I've been through ServiceBox and can't find it!
I'd guess a Peugeot dealer is you only option ...
gazza82
PostPosted: Wed Dec 17, 2014 5:11 am Up
Hold on ... it's under Lubrication .. OIL FILLER DECANTING UNIT UNIONS
PostPosted: Wed Dec 17, 2014 5:31 am Up
It makes it easier finding a part on servicebox when you know which engine you're looking for.
I won't click on the link in the thread as you never know what you're clicking on, and let's face it, it's not that hard to add a picture to a post.
NiGHTS
PostPosted: Wed Dec 17, 2014 5:35 am Up
Thanks gazza82, you're a legend mate. Smile
PostPosted: Wed Dec 17, 2014 5:40 am Up
I'd cut the pipe off the connectors and get some cheap silicon hose from Ebay. Bound to be cheaper than the Peugeot dealer.
gazza82
PostPosted: Wed Dec 17, 2014 6:01 am Up
It does, it also helps to known how the warped minds of Peugeot work when trying to trace it.
I guess I'm a bit more trusting ... a quick look at NiGHTS posts suggested it was a GTi engine and as we have that in our CC and the same pipe is causing me problems (it's snapped), I thought is was worth a try .. and no, it's not hard when you know or have done it a few times Wink Although that one is causing me grief when trying to create an image link ..
Project2062014
PostPosted: Wed Dec 17, 2014 6:04 am Up
£27 from peugeot new . Or go scrappys .
I used silicon hose to replace mine .
gazza82
PostPosted: Wed Dec 17, 2014 9:28 am Up
I tried normal rubber hose on ours to join the break. That lasted about 9 months then one day I found it on lying on the thermostat housing. It had simply gone soft, stretched and just fallen off!
Got silicon on now and need to check that at some stage.
I may just get a new pipe in the new year ... I need to get some new engine cover turn-clips too
NiGHTS
PostPosted: Wed Dec 17, 2014 4:40 pm Up
How did you guys connect a silicon hose to the ends? I can't see how it could be done...got any pics?
I'll probably just give Peugeot a call and ask for the part. Hopefully they know what Im talking about.
gazza82
PostPosted: Thu Dec 18, 2014 8:40 am Up
Ours snapped about halfway along the thicker pipe, so I rammed the broken ends into the silicon hose as far as I could and it felt tight. I will check next time the car is in my possession as it's my daughter's daily and I only get to see it occasionally .. normally just following a telephone call that starts "Daddy .... " .... Smile
Leegsi
PostPosted: Thu Dec 18, 2014 9:39 am Up
For the sake of £27 I would replace it
gazza82
PostPosted: Thu Dec 18, 2014 11:49 am Up
She would just love that for Christmas ... Smile Besides, I still have a black mark for buying her new tyres for a birthday ...
I will, just can't be arsed to got to my Pug dealer where's there is no where to park close by and I'd be mingling with the hoards doing their Christmas shopping nearby ...
PS Need some Christmas smilies guys ... with at least one "Bah Humbug"
PostPosted: Thu Dec 18, 2014 2:06 pm Up
As I said, easiest way of fixing it permanently is to get some silicone hose from Ebay! Will cost £5 at most!
