Latest: ArtistKS
Overall: 17145
Online Now [66]:
Visitors: 65
Today: 9033
Total: 116024406
Forums › The Car › 206 Problems › Please help!!! 2003 206 Look
Eblandie
PostPosted: Sat Jan 03, 2015 9:00 am Up
Hi there, my daughters 206 recently broke down and wouldn't start. I investigated with the help of my father in law and found the timing belt needed changing. We have done this and the car still won't start.. The starter motor engages and all the crank and engine is engaging but still no joy. Eco mode is displayed on dash. Will diagnostics be my best bet. Any help would be much appreciated.
macj
PostPosted: Sat Jan 03, 2015 9:11 am Up
Had the cam belt come off
PostPosted: Sat Jan 03, 2015 11:35 am Up
Sounds like the 'timing' needs to be set up.
PostPosted: Sat Jan 03, 2015 12:40 pm Up
timing belt needs to be set correct,and hope that there is no internal damage done when it stopped working,also you might need to check the crankshaft sensor.
Project2062014
PostPosted: Sat Jan 03, 2015 1:04 pm Up
Hi . Did the cambelt belt snap ?
Eblandie
PostPosted: Sun Jan 04, 2015 7:35 am Up
onNo the cambelt had not snapped, there were some teeth missing on the belt, so it wasn't turning properly.
Eblandie
PostPosted: Sun Jan 04, 2015 7:37 am Up
Daft question I know, but where will I find the crankshaft sensor
macj
PostPosted: Sun Jan 04, 2015 7:54 am Up
you need to replace the belt with the correct timing pins and do a compression test..... this is to see if any contact was made between valves and pistons when the timing slipped.... you may be looking at a "head off" job Sad
Eblandie
PostPosted: Sun Jan 04, 2015 8:01 am Up
Timing has been done with the correct pins. My father in law put his hand over exhaust, there was no compression he said.
macj
PostPosted: Sun Jan 04, 2015 8:09 am Up
Then you need to take the head off. I would do a proper compression test on each cylinder first to identify which cylinder or cylinders are affected. You may find a second hand head cheaper if there are more than two cylinders affected.
I am assuming that your father in law knows his stuff and its possible to replace the damaged valves if there are only a few bent
Eblandie
PostPosted: Sun Jan 04, 2015 8:12 am Up
Yes he's pretty good. Thanks for your help, much appreciated
macj
PostPosted: Sun Jan 04, 2015 8:18 am Up
Its what the forums here for Wink
zniko1990
PostPosted: Sun Jan 04, 2015 11:30 am Up
Well done Macj Smile
zniko1990
PostPosted: Mon Jan 05, 2015 12:19 pm Up
He needs to research how to time one of these before starting the job. I don't mean to undermine your trust in him but anyone knows that if teeth are missing the timing will have moved enough to bend valves.
Eblandie
PostPosted: Mon Jan 05, 2015 1:59 pm Up
