Online Now [676]:
Visitors: 675
Today: 47559
Total: 105624535
Forums › The Car › 206 Problems › horn dead
horn dead
shedog
PostPosted: Tue Feb 03, 2015 2:05 pm Up
does 1.4 hdi s 2004 have horn relay if so where Confused
PostPosted: Wed Feb 04, 2015 1:05 am Up
Yes.
Diagram 2 of this thread
Have you checked if power is reaching the horn?
Also worth checking the connections to the horn and the horn itself.
Spotfist
PostPosted: Wed Feb 04, 2015 4:01 am Up
My horn is also knackered, I have read online that the bumper might need to come off which seems like a huge bit of work. I can see the horn behind the grill but the clips for the grill are on the other side so don't know how I would get it back on if removed...
PostPosted: Wed Feb 04, 2015 4:20 am Up
I think the horn can just about be accessed from underneath.
DREWDEN
PostPosted: Wed Feb 04, 2015 5:42 am Up
Did mine from underneath, wires were corroded in the plug connector.
If i also remember the wires from the horn, goes up to another connector near the fan relays
206 2ltr Hdi glx 53 plate
shedog
PostPosted: Wed Feb 04, 2015 9:45 am Up
thanks macca thats very helpfull will check everything when it stops raining i have bin told that the grill will push back as its only on clips then pull it back to clip it back but its tight
PostPosted: Wed Feb 04, 2015 12:55 pm Up
If you need a new plug the are called Junior Power Timer Plugs.
Project2062014
PostPosted: Thu Feb 05, 2015 9:55 am Up
easy job pal
Dont be scared of a bumper !
