Latest: Beduff1977
Overall: 17134
Online Now [858]:
Visitors: 857
Today: 222233
Total: 107882257
Forums › The Car › 206 Problems › Strange noise when steering
Go to page Previous  1, 2
PostPosted: Mon Mar 12, 2012 5:52 pm Up
My local garage want to charge me £240 total to supply and fit a new pump Sad
Martind
PostPosted: Mon Mar 12, 2012 5:58 pm Up
Ouch Shocked its half hour to an hour job mate and very easy to do Very Happy
NathanG
PostPosted: Mon Mar 12, 2012 6:14 pm Up
How much, they buying the tools to do the job aswell are they?
Pump £40, new fluid £7. 20-30 min job. Easy job aswell. Get a mate to help, always easier with 2 especially removing the aux belt.
PostPosted: Mon Mar 12, 2012 6:25 pm Up
I have a pump that you could have for cheap enough as I need the space.
As long as you don't have variable power steering
lisa206
PostPosted: Tue Apr 21, 2015 8:44 am Up
Hi , just come across this thread as I am getting the same fault. Did you change the pump and did this solve the problem ??
Thanks Smile
LISA 206 180
stevo1600
PostPosted: Tue Apr 21, 2015 4:42 pm Up
thats a massive bump of an old thread Smile
HowlingMadMurdock
PostPosted: Tue Apr 21, 2015 7:50 pm Up
If you get a screaming noise from the power steering it may be the pump or it may be an o-ring that has failed. I had the loud screaming noise on my X-reg 206 and it was the o-ring that had begun leaking. 20p for the ring.
The leak is not bad so topping up with steering fluid will do the trick for £4. It'll get worse over time so get it fixed but a pump can be bought for £20 online. Check your lines and your fluid first.
Shop around, Google will save you a fotune Smile
I ain't nuts, I'm condiments, I've been promoted
lisa206
PostPosted: Thu Apr 23, 2015 4:22 am Up
Ive had a look under the car and can see there's a split in the power steering pipe, so the fluid is leaking. Booked in to garage to be fixed now.
LISA 206 180
Page 2 of 2
