Latest: tbafonso
Overall: 17130
Online Now [184]:
Visitors: 183
Today: 9992
Total: 102084323
Forums › The Car › 206 Problems › PLEASE HELP!... Cut out problem
jay_gti180
PostPosted: Thu Mar 10, 2016 9:26 am Up
Hi guys,
So i have a Gti 180 and having serious issue with cutting out, cant seem to work out the problem. Driving, dip the clutch and all of a sudden revs drop and cuts out, dip the clutch again and jumps to life. Seems to be more prone directly after i have hammered it when cold...
Im so confused as to what it could be now.
Ive changed:
Spark plugs
Coil pack
Map sensor
Crankshaft sensor (between gearbox and engine?)
Earths from negative to gearbox and gearbox to arm
I have no idea what else this could be and its causing me a hige headache.
Please help
Jay
VorTechS
PostPosted: Fri Mar 11, 2016 8:24 am Up
Staff - Vortechs
Have you checked the ICV?
jay_gti180
PostPosted: Sat Mar 12, 2016 1:18 am Up
onWhats the ICV mate?
mtempsch
PostPosted: Sat Mar 12, 2016 5:56 am Up
Idle Control Valve.
But I was under the impression that 206s with electronic throttle (which I believe all 180/RCs have) didn't have a separate ICV, and instead the ECU/electronic throttle handled idle. I could be wrong though, have been spared from having to dig into the engine...
Silvermetallic 2004 206 RC
jay_gti180
PostPosted: Sun Mar 13, 2016 8:43 am Up
Turned out to be the camshaft position sensor, thanks for your help anyways mate
