Latest: Beduff1977
Overall: 17134
Online Now [243]:
Visitors: 242
Today: 55768
Total: 107161152
Forums › The Car › 206 Problems › Gearbox oil change
Gearbox oil change
Chriz1
PostPosted: Sat Mar 12, 2016 11:12 am Up
Does anyone have a guide for gearbox oil change on 2.0 hdi?
Also what viscosity Is recommended, cars getting notchy going into 1st all other gears are fine.
southwestchap
PostPosted: Mon Mar 14, 2016 11:59 am Up
I've used this stuff before, seems to be fine
www.nielsencdg.co.uk/a...l#SID=1087
2 litres needed.
Drain plug on bottom of box (get a new copper washer)
filler is at the top - plastic 17mm bolt/nut (may need to remove battery box) level bung on the side
Chriz1
PostPosted: Mon Mar 14, 2016 12:59 pm Up
Thanks I got some from the dealers in the end same stuff. And thankfully it's sorted my problem
