Latest: Beduff1977
Overall: 17134
Online Now [102]:
Visitors: 101
Today: 23510
Total: 107128993
Forums › The Car › 206 Problems › Brake Discs and Pads advice wanted
Deano69
PostPosted: Sat Apr 23, 2016 3:41 pm Up
Hi All,
I noticed the other day the Discs on the front have a nice 4-6mm ridge around the outside... so thought I`d change them when the pads are due soon.
This is on my 1.4 Verve (otherwise bog standard)
Anyway, having a flick around on europarts website today,
they seem to do 4 brands
Eicher £10 each disc
Pagid £20 each disc
Brembo £20 each disc
and Bosch £25.. always the most expensive...
So anyone got any experience of the Eicher ????
They seem so cheap, can they be any good ????
They are vented discs by the way .
thanks for any advice
cheers Smile
PostPosted: Sun Apr 24, 2016 4:45 am Up
Brembo or Ferodo for braking friction components every time.
PostPosted: Sun Apr 24, 2016 4:51 am Up
I always fit Pagid stuff to my cars. They've always been fine.
gazza82
PostPosted: Mon Apr 25, 2016 5:05 am Up
Eicher are a waste of money ..
