Posted: Sat Apr 16, 2016 7:29 pm |
Hi. Got a bit of an odd one with my wife's motor. It's a 2004 206sw 1.4 8v (the tu one). She's lost use of her clutch, the pedal has gone floppy etc. Sounded like the cable had gone so picked one up and drove from bacup to Scarborough to find it's not the cable. The clutch fork is loose. It can move maybe 2 inches up and down, and of only slightly held in the "disengage" position it sounds like a massive tin full of dried peas being shaken. The car can still be driven by floating the gears, and all gears work spot on without any issue, but there's no use of the clutch pedal
What goes on inside the box below the fork is beyond me unfortunately as I've never needed to delve into it so wondering if anyone can make any suggestions? Does it need the box replacing / reconditioning, or is it just clutch parts? I've still got the cable and from what I've read, I'm best to replace that with the clutch anyway. Any pointers appreciated
Posted: Sun Apr 17, 2016 2:17 am |
Remove the gearbox & have a look what's going on.
Posted: Sun Apr 17, 2016 9:11 pm |
Need's the gearbox removing to inspect what's going on inside the bell housing, but sounds like an issue with the clutch release bearing either stuck in the pressure plate, slipped off the clutch fork or collapsed.
Where abouts are you located?
Posted: Tue Apr 26, 2016 6:35 pm |
Cheers for replies. Thrust bearing collapsed. Clutch replaced and all is well. Except my wallet lol
Posted: Thu Apr 28, 2016 4:35 pm |
how much did the new clutch cost to be fitted ?
had a similar problem myself...
