Latest: sparrowdclxvi
Overall: 17139
Online Now [164]:
Visitors: 163
Today: 4805
Total: 113280359
Forums › The Car › 206 Problems › Tachometer problem
Tachometer problem
Sofa.King.Happy
PostPosted: Thu Sep 01, 2016 2:05 pm Up
I bought this car with tachometer already working bad. It lays below 0 when driving on constant speed and it rises and drops while reving.
What can the problem be?
(How do I use [video][/video] anyway?)
www.youtube.com/watch?v=Y5Cy1h6_9Zw
PostPosted: Thu Sep 01, 2016 3:02 pm Up
Either the plastic needle is loose on the metal shaft OR the drive motor for the gauge is knackered.
Both are common issues with these non plexed instrument clusters.
Sofa.King.Happy
PostPosted: Thu Sep 01, 2016 4:00 pm Up
If it's the needle, will I only need tighten it up; no parts needed?
If it's the drive motor, does it fit from any other 206 cluster?
What about changing whole cluster, does it need programing to work? Is white one is a bolt-on?
Sim
PostPosted: Mon Sep 05, 2016 9:03 pm Up
I remember Pez replacing a multiplexed cluster with another multiplexed one, that in addition had oil temp gauge. Everything worked out of the box, only the oil gauge had to have a switch flicked via PP2000.
So as long as you find another preplexed cluster, it should start up, no matter the dials' colour.
You might as well tinker with the illumination colour once you're at it Cool
Daily Red GTi 180, year 2004 (VorTechS' sEXy Beast (being) remasteRed)
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
