Latest: airmastertapes
Overall: 17133
Online Now [398]:
Visitors: 397
Today: 11855
Total: 106545504
Forums › The Car › 206 Problems › speedometer
speedometer
adran
PostPosted: Sun Sep 25, 2016 2:22 pm Up
Hi, i have a peugeot 206 1.4 petrol 1999,
the speedo has stopped working, can anyone
help with the problem please,
PostPosted: Sun Sep 25, 2016 2:28 pm Up
Does the odometer still clock up the miles? Does the interior light flash and beep if you drive with the door open slightly?
adran
PostPosted: Sun Sep 25, 2016 2:47 pm Up
The interior does flash and bleeps with door open,
i can not make out mileage not illuminated.
PostPosted: Sun Sep 25, 2016 4:34 pm Up
If it flashes that suggests the ECU is getting a speed signal from the gearbox speed sender. Chances are it's a speedo problem. Fix the display though to check. I see no reason for the odometer to not be working.
adran
PostPosted: Sun Sep 25, 2016 4:42 pm Up
OK i will check the display and get back to you if i may, thank you for your help, adran.
I took the plastic cover off the display unit and moved the speedo arm just a little took the car for a spin the speedo and mileage seems to work fine, (it must have stuck on zero) i also replaced the milometer bulb, thanks for all your help, it also might help others with the same problem, adran.
