Latest: S2cgm
Overall: 17178
Online Now [297]:
Visitors: 296
Today: 43986
Total: 136628850
Forums › The Car › 206 Talk › comm 2000
comm 2000
Go to page Previous  1, 2
commandosqueak
PostPosted: Sun Mar 19, 2017 3:52 pm Up
You should be able to change them as long as the unit supports the features you car has. Worse case I can send you the stalk with the button, its not a hard job to change just a bit fiddly. The rest of it is junk but the stalks work fine.
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
steviebee
PostPosted: Sun Mar 19, 2017 4:05 pm Up
hi. The Dav unit I have has all the same features as my Delphi one, no auto anything. I did try to change just the end bit but they are different. Bit of a cheek I know but did you have a picture of the one one you have got. They just pull off as you know. My Delphi one has 2 ball bearings on the shaft, whereas the Dav one dosnt. If I could get away with just changing the end bit that would be great.
regards.
Steve
frenchie steve
commandosqueak
PostPosted: Sun Mar 19, 2017 4:13 pm Up
Well the stalks i have here are off a delphi unit. All i have left is the stalks thinking they may be useful. the rest of it is knackered so was binned. Once the airbag and steering wheel plus the plastic surround are off there is a 10mm bolt on a clamp to undo. one loosened leave the clamp where it is and just unhook the clips and it slides write off. I don't know of any unit having ball bearings?
here is a picture of the clips
steviebee
PostPosted: Sun Mar 19, 2017 4:58 pm Up
Mine has 2 ball bearings on the shaft inside the end thingy that you twist. How much would you want for the stalk inc p+p/
regards.
Steve
frenchie steve
commandosqueak
PostPosted: Sun Mar 19, 2017 5:08 pm Up
If you pay for P&P You can have it. Just pm me your address. Once sent I can send you a paypal request. Sound good?
steviebee
PostPosted: Sun Mar 19, 2017 5:12 pm Up
Your a star, thank you. PM sent
Regards
Steve.
frenchie steve
commandosqueak
PostPosted: Sun Mar 19, 2017 6:00 pm Up
hmm not received anything yet... Admin are we having any issues?
steviebee
PostPosted: Sun Mar 19, 2017 6:13 pm Up
Just resent pm.
Regards.
Steve
frenchie steve
steviebee
PostPosted: Sun Mar 19, 2017 6:18 pm Up
Doh! I forgot to put a subject. Hopefully you have it now.
regards.
Steve.
frenchie steve
commandosqueak
PostPosted: Sun Mar 19, 2017 6:19 pm Up
yep i got it now !
steviebee
PostPosted: Sun Mar 19, 2017 6:22 pm Up
Great. I will wait till I hear from you.
many thanks again.
Steve.
frenchie steve
steviebee
PostPosted: Mon Mar 27, 2017 1:02 pm Up
Well after nearly 14 months of dithering about, I now have a fully functioning MFD thanks to commandosqueak. Many thanks to you all for your help. I can now carry on with the upgrades Very Happy
frenchie steve
commandosqueak
PostPosted: Mon Mar 27, 2017 1:50 pm Up
awesome just need to sort mine out now haha
Page 2 of 2
