Online Now [531]:
Visitors: 530
Today: 50609
Total: 105627584
Forums › The Car › 206 Talk › 1.1S petrol fails to start
Peugeot1989
PostPosted: Sat Mar 18, 2017 11:27 am Up
Having changed the coil pack, spark plugs, several sensors and had the ecu repaired my 206 still fails to start. Getting good spark and fuel flow. Strange thing is that if I remove the 15 amp fuse for the petrol pump the car will fire up and run for a few seconds until the fuel supply dries up. Any suggestions would be appreciated.
commandosqueak
PostPosted: Sun Mar 19, 2017 4:35 pm Up
try to start the car, then open that door with the keys in the ignition. Does the car beep at you to say the keys are in the ignition. Also you could try a BSI reset. Filing that It will be worth having the car plugged into peugeot planet to see whats going on. especially as you have "repaired" the ECU
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
Peugeot1989
PostPosted: Mon Mar 20, 2017 3:45 pm Up
Thanks for the info. I tried to start the car and opened the door with the key still in the ignition- no beep.
