Forums › The Car › 206 Problems › Power Steering Hose leak |
Posted: Wed Nov 15, 2017 12:30 pm |
Hi
My 206 1.6 leaks fluid from the middle of the rubber PAS hose. It is crimped at each end on to the metal pipe. If I get a new hose from Pirtek , how easy/difficult is it to crimp it on to the pipe ?
I have to destroy the hose to get it off to take to Pirtek, and will therefore be without transport.(Pirtek won't do it)
Tia
Posted: Wed Nov 15, 2017 3:23 pm |
The hoses can be removed from the car. The subframe might need lowering to provide access to the steering rack.
Posted: Wed Nov 15, 2017 7:06 pm |
Thx Edward.
The pipes run across the top just behind the rad, I was hoping just the rubber hose could be replaced but it looks as though the whole of the pipe will have to be replaced.
