Latest: TigerHunters
Overall: 17144
Online Now [51]:
Visitors: 50
Members: 1
Today: 37408
Total: 115868528
Forums › The Car › 206 Talk › Retrofit cruise control with later ECU
kukasfedel
PostPosted: Fri Jan 26, 2024 12:12 pm Up
Hello,
I have an 1.4 petrol 206 from 2008, and I wanted to retrofit CC in it.
I got the Cruise control, which can be fit under the turning signal without an issue.
The car, by factory default has all the switches and cabling at the pedals.
When I checked how to fit it, I read tons of articles and seems like all should be fine.
The last step would be to enable the CC stuffs in the ECU.
I found a chop shop who had PP2000 (people afraid to acknowledge around here in Hungary haha), and when he tried to enable, it wasn't available in the ECU.
He told me, the later manufactured cars were equiped with a downgraded ECU, which excluded all extra functions, for the sole purpose not to be able to retrofit stuff easily.
Seems like mine is similar Sad
Do you know if there's any way to still retrofit CC?
If not I'll just sell the stuff I bought for it.
I live in Budapest, Hungary.
Cheers,
Szabi
PostPosted: Sun Jan 28, 2024 10:30 am Up
IIRC as its been a few years since I tinkered with 206s & Planet - some of the engine ecu fitted to the 206 had the cruise control function locked out in the engine ecu software so it couldn't be enabled.
Cruise control needs to be enabled in both the BSI & engine ecu to work.
kukasfedel
PostPosted: Sun Jan 28, 2024 1:16 pm Up
Yeah that's the issue, it can't be enabled at the moment.
So that means, if they are locked out, there's now way to unlock/flash/whatever them to be available? Means, no CC for me? Sad
PostPosted: Sun Jan 28, 2024 6:16 pm Up
It maybe able to be flashed with another tool to rewrite engine ecu software from something like a 307 with the same engine but I've never attempted it so more research will be needed online.
OR engine ecu swop with a suitable unit but you would have to recode it for the immobiliser so try & get the VIN from the doner vehicle or get a free running or unlocked ecu.
kukasfedel
PostPosted: Sun Jan 28, 2024 9:16 pm Up
If I get a donor ECU, and if it won't work anyhow, can I just simply put my original one back and the car won't be bricked?
Sounds like something I could ruin the whole vehicle with Very Happy :D
Sim
PostPosted: Mon Jan 29, 2024 11:50 pm Up
Szia!
Instead of PP2000, try with Lexia (for Citroens) and select Citroen C2 for your 206 (this is e.g. how I successfully programmed new keys, because PP2000 failed in that regard).
The older SW version you have, the better.
This loong thread mentions that Peugeot disabled the ECU cruise control switch in their newer PP2000 software, due to Renault having some fatal incidents with their cruise control, so people can no longer retrofit it.
Obtaining a very old version of PP2000 might also help in changing the "now-locked" features of an ECU.
If all of the above fails for you, I'll try to explain how to go down the ECU flashing route, but with varying success.
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
kukasfedel
PostPosted: Tue Jan 30, 2024 11:04 am Up
Thanks for the tip, I'll try to ask around for Lexia or older PP2000.
Finding this guy was already took way too long, but who knows Very Happy
I'm not sure if it's locked out in the SW itself, or is it not even included in the ECU.
The guy seemed sure about how to enable the CC stuff, so I believe his PP2000 should've been able to enable.
Worth a try anyway.
If the flashing stuff is quite random, I'll just live without CC. Would be fun to have, but considering how unlucky usually I am, I won't brick my car Very Happy
