Latest: Stu-mill
Overall: 17131
Online Now [55]:
Visitors: 54
Today: 13174
Total: 104900778
Forums › The Car › 206 Talk › Expensive service
Expensive service
PostPosted: Sat Jul 17, 2010 4:23 am Up
colin wrote:
price for lower arm is too cheap,garage must be using the nastiest pattern parts available.both sides ideally should be done and tracked.but i suppose your getting rid of it soon,not a great advert for it though.as for service do it yourself it isn't rocket science.
42, 62 or 81quid from eurocarparts so 78 looks expensive to me lol
colin
PostPosted: Sat Jul 17, 2010 5:07 am Up
like i said must be using the nastiest pattern part to supply and fit for that money.what bit dont you understand. Laughing
Locky
PostPosted: Sat Jul 17, 2010 5:56 am Up
Cheers for the input - I see you are as chirpy as usual Colin. Whilst I appreciate servicing isnt rocket science, you still need time to do it, and I just dont have that or inclination to change oil, filter, fuel filter, tighten stuff up, flush the systems, inspect everything etc as I have already explained.
I also explained why I had to have the work done where I did. Your opinion of them using a 'nasty' pattern part is just that - an opinion. Regardless of price, any future owner is going to know its had a decent specialist service, a thorough professional inspection and replacement of critical parts.
I fail to see how any of this is detrimental to a sale, as opposed to some back yard DIY maintenance.
2001 HDi D-Turbo, China Blue, Multiplexed.
colin
PostPosted: Sat Jul 17, 2010 6:15 am Up
wow you do make a service sound like a lot of work.if your happy with your specialists using the cheapest parts they can find good luck to you,part of doing it yourself is knowing what parts,fluids etc you have used.you don't even have spark plugs to change on your diesel,would be serviced in less than 1 hour.cheap wishbones are not worth the labor to do twice.but hey. Wink
ExoVyper
PostPosted: Mon Jul 19, 2010 8:49 am Up
oh lol somebody doesn't know about 206's xD
no matter what wishbones you put on the 206 eats them with admirable gusto everytime.
especially when you have the heavier motors in, my 206 loved the wish bones i got put in a year down the line and it had destroyed two! Razz
but aslo when people say they dont have time then they just don't. i'm a heavy machinery mechanic and i can easily do my wishbones, but i put the old girl into a garage as with being at work constantly or doing something else i physically couldn't get round to it (not having a 2 post lift didn't help either Razz )
PostPosted: Mon Jul 19, 2010 12:31 pm Up
Not true at all.
dturbopeck
PostPosted: Mon Jul 19, 2010 1:14 pm Up
mate if you want this sorted for alot less give me a pm with your reg and i will sort you out a price as i work at R and P Woods in heaton and do alot of my own work on the weekends
ExoVyper
PostPosted: Mon Jul 19, 2010 2:12 pm Up
Edward wrote:
Not true at all.
oh i thoguht they did :S nevermind Razz
Locky
PostPosted: Mon Jul 19, 2010 2:36 pm Up
Thats good to know cheers mate. I see your place has a good rep on PistonHeads too. I will defo keep you in mind for the future regardless of car, as ive already had the work on this thread done.
ExoVyper wrote:
Edward wrote:
Not true at all.
Im sitting on the fence with this one. I do actually drive exceptionally carefully to try and miss the majority of pot holes and craters but I do drive the car pretty hard. Think this is the 2nd one, Pug did the first one.
Cheers guys.
dturbopeck
PostPosted: Mon Jul 19, 2010 2:51 pm Up
ok mate no problemo!
Locky
PostPosted: Mon Jul 19, 2010 2:55 pm Up
I expect you will see me soon enough if my car doesnt sell! The local garage Anne St I normally use I have lost faith in - Pug dealer is out, and by all accounts from what some have said on this thread ive been done up like a kipper by Croxdale. Im running outta mechs! And I pretty much pass your place each day to get out to Cobalt business park near silverlink.
Sorry to see your 180 is going... Sad
colin
PostPosted: Fri Jul 23, 2010 7:53 am Up
I fail to see how any of this is detrimental to a sale, as opposed to some back yard DIY maintenance.[/quote the work needed on your car is far from specialist,cheap lower arms are just that,nasty copies made to a price.most if not all independent garages probably use the cheapest parts they can source,giving the impression the 206 eats lower arms.i would not recommend anyone use the cheap rubbish available if you plan on keeping your car.my backyard diy maintenance efforts mean i don't have to moan about expensive service costs and don't use crap parts.yours chirpily.
colin
PostPosted: Tue Jul 27, 2010 4:22 am Up
some mechanic you must be.iam far from being a mechanic but by doing the job myself could easily change both wishbones in about 1 hour,without the aid of 2 post lift.
PostPosted: Tue Jul 27, 2010 4:31 am Up
Really?! I find that hard to believe.
It took myself and a qualified mechanic 3 hours since they would not budge and the driveshafts had to be removed too.
colin
PostPosted: Tue Jul 27, 2010 4:39 am Up
the drive shaft is one nut,and i was allowing for that in my estimated time,granted i struggled the first time i did this job,but like i said iam far from a qualified mechanic.i stand by my statement of 1hour give or take a few mins.as for not budging one smack of 4 pound club hammer = seconds.the drive shaft does not have to be removed.
Page 2 of 4
