Latest: airmastertapes
Overall: 17133
Online Now [588]:
Visitors: 587
Today: 91970
Total: 106625561
Forums › The Car › 206 Talk › 206 gti rough running/increased revs/engine management light
liteweight66
PostPosted: Mon Sep 06, 2010 1:30 pm Up
My wife 206 gti has started to rough running/increased revs/engine management light when being started from cold? Any ideas chaps? Question Question Question Question Question
every pittance helps
PostPosted: Mon Sep 06, 2010 1:36 pm Up
plugging into computer will most likely give the fault as engine light has been on etc.
PostPosted: Mon Sep 06, 2010 1:44 pm Up
Hydraulic lifters or coil pack are normal problems...if it will start but only run with throttle I'd blame the idle control valve...
