Posted: Wed Sep 08, 2010 5:45 pm |
can somebody tell me the best way to spray my parts . can never get the shiny finish , is there a guide or something , could do with knowing every step , help please thanks
Posted: Wed Sep 08, 2010 6:03 pm |
Check the 'Styling How-To' guides.
Posted: Thu Sep 09, 2010 1:42 am |
I've checked the guides and there seems to be a lack of suggesting sanding between each coat.
I'm currently in the middle of doing a test on some rub strips, process so far:
Sanded the rub strips using wet/dry 800
Primed, sanded with wet/dry 1200 x 3
Painted, sanded with wet/dry 1200 x3
Next process for me is laquering (Laquer, sand wt/dry 1200 x7) but my question is once I have the final layer of laquer on, do I need to sand this back ? It will look quite dull? I guess polishing comes into play somewhere
