Forums › The Car › 206 Talk › Best & Cheapest Service Parts |
Posted: Sat Sep 25, 2010 7:20 am |
I'm looking to service my 206. Bought it used in June and not sure how well its been looked after by its previous owners so was considering changing all fluids. Coolant/gear oil/brake fluid.
It's a 1.1 LX 01 model.
Wheres the best & cheapest place to buy the fluids (+which ones should I be using) and the spark plugs/filters.
Posted: Sat Sep 25, 2010 7:33 am |
Euro Car Parts...
Posted: Sat Sep 25, 2010 7:34 am |
try www.eurocarparts.com and you can type your reg number in and itll come up with the parts for your car
Posted: Sat Sep 25, 2010 7:45 am |
Cool. Thanks for the link. Just wondering for the oil/fuel filters does it matter which one you go for?
Also oil. Carlube Engine Oil (10W40 Semi Synthetic Engine Oil (5 Litre) is only £13 but some 4 litre is over £30 is there a noticeable difference in performance?
