Latest: SA01
Overall: 17138
Online Now [74]:
Visitors: 73
Today: 7916
Total: 111254511
Forums › The Car › 206 Talk › small to big??
small to big??
JmeRaynor
PostPosted: Sun Oct 03, 2010 8:52 am Up
Does anyone or have any one ever put a bigger engine in a smaller engine car?
ive got a 1.1 and the engine is just all over the place, (nacked basically)
and i've seen a 1.4 engie on ebay would it be possible to add this engine to the car? would the car handle it?
Mattie-RS
PostPosted: Sun Oct 03, 2010 9:01 am Up
can put any engine in
Id say go for the 1.6 8v as its a very similar engine, just bigger bore size, and direct fit!!
eddrj
PostPosted: Sun Oct 03, 2010 9:02 am Up
can do yeah would work
Old car 2000/ 206 2.0 hdi.
apjs87
In a word, yes
No longer a 206 owner
Astra H sxi. 1.7Cdti
T_bandery
PostPosted: Sun Oct 03, 2010 9:04 am Up
As mattie said the 1.6 will be a direct fit Smile
Why not put in the GTi engine?
JmeRaynor
PostPosted: Sun Oct 03, 2010 9:05 am Up
could do Razz what about the ecu would that all be the same not need anything doing, just a basic take out and put in job?
Drive with pride!
kevin
PostPosted: Sun Oct 03, 2010 9:19 am Up
ECU should really be changed however it would run on the old one but would give you alot of hastle later on so would defo do mate.
Mrs_Howey
PostPosted: Sun Oct 03, 2010 9:23 am Up
If you put the 1.6 engine it will increase your tax to like £200 odd a year, were as the 1.4 tax is £125 for a year Smile
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
PostPosted: Sun Oct 03, 2010 9:24 am Up
the 1.4 and 1.6 8 valve engines will bolt straight in and will require very little wiring to get it running assuming u put a non plexed (pre 2001ish) into a non plexed car of vice versa
the gti engine is a lot more involved uses a different gearbox more wiring different exhaust etc plus a lot more parts will need upgrading such as brakes and suspension to cope with it
Teebag
PostPosted: Sun Oct 03, 2010 9:25 am Up
need engine, wiring loom bsi and ecu
my garage inc mod list:
- Antix
Mattie-RS
PostPosted: Sun Oct 03, 2010 9:54 am Up
if your car is pre 2001 then id def go for the 1.6 8v out of a pre 2001 also
engines on ebay and that mostly come with gearbox ecu and loom, so its a simple out with the old in with the new,
Ash
PostPosted: Sun Oct 03, 2010 10:41 am Up
Assuming he tells them...
Wiliam_morgan
PostPosted: Sun Oct 03, 2010 10:43 am Up
shouldnt do, my tax in my Fiesta Zetec s which is a 1.6 is only 155 a year!
Mattie-RS
PostPosted: Sun Oct 03, 2010 10:45 am Up
And my VTS which is a 1.6 16v is only 135 i think Razz
But my old 206 1.6 was 190 a year
JmeRaynor
PostPosted: Sun Oct 03, 2010 11:03 am Up
who said i'm telling Razz o dear haha, i had a feeling ecu might need changing good look on Ebay I have found some decent listings and bidding on them now Very Happy
Drive with pride!
