Forums › The Car › 206 Talk › Getting rid of aircon compressor |
Posted: Sun Oct 03, 2010 5:16 am |
So how do I go about getting rid of my aircon compressor? I've ripped out the rest of the system but what do I do with the pump?
It's a 99 gti so an ew10j4 engine. Do I need a pully there when I remove it or is there a different drive belt?
Help please
| ICE goes in drinks. NOT in cars. | |
Posted: Sun Oct 03, 2010 5:17 am |
Euro Car Parts list belts for no air con.
Posted: Sun Oct 03, 2010 7:29 am |
Yes, but can you confirm that the non aircon version has the same tensioner positions as I can't see how it would be routed without the compressor there in it's current configuration.
