Posted: Mon Oct 11, 2010 1:51 pm |
Hi people. I'm hoping to buy a 206 2.0 hdi soon. I've got about £2500-3000 to spend. Knowing what kind of age/condition car this will get, what things should i look out for? i've never had an older higher mileage car before. Also where to look other than autotrader or ebay? If anyone can point me in the right direction would be much appreciated.
Posted: Mon Oct 11, 2010 1:55 pm |
Try pistonheads.co.uk... But I found mine on Autotrader. You should get one about 03 plate/about 60000-80000 miles... So that's not bad. You need to see if it's had it's cambelt done, or if it's due to be done. Also check the exhaust & ball joints & such. Check the condition of the radiator too for rust & decay!
| China Blue 2.0 HDi DTurbo
-Sports Bumpers -Rear Spoiler -Rear Lexus Lights -SP Fuel Cap -SP Bonnet Vent -SP Upper Grille -SP Lower Grille (Zunsport) -Crystals | |
Posted: Mon Oct 11, 2010 1:59 pm |
| Twidly wrote: |
| Try pistonheads.co.uk... But I found mine on Autotrader. You should get one about 03 plate/about 60000-80000 miles... So that's not bad. You need to see if it's had it's cambelt done, or if it's due to be done. Also check the exhaust & ball joints & such. Check the condition of the radiator too for rust & decay! |
thanks twidly. How do you check ball joints? Are the engines ok with that kind of mileage?
Posted: Mon Oct 11, 2010 2:05 pm |
| iansgtihdi wrote: |
| Twidly wrote: |
thanks twidly. How do you check ball joints? Are the engines ok with that kind of mileage? |
The engine's are fine! Mine's done 92K & it sounds like a dream. My Mum's has done 110K & drives perfectly. Diesels will run forever!
IIRC you have to stick a screwdriver in it & wiggle it or something... I think it's not supposed to move a lot... someone else with more knowledge on that will no doubt provide you with better information. Cause I haven't actually done it myself, just know it should be done as they're notorious for clunking & failing MOT's.
Posted: Mon Oct 11, 2010 2:16 pm |
Ask if the crank pulley has been changed as well, because they are a common fault on the hdi
Posted: Mon Oct 11, 2010 2:22 pm |
| Lee wrote: |
| Ask if the crank pulley has been changed as well, because they are a common fault on the hdi |
is there any symptoms that the pulley is going to fail?
Posted: Mon Oct 11, 2010 2:24 pm |
| Seabook wrote: |
| Lee wrote: |
is there any symptoms that the pulley is going to fail?  |
Rattles and like a metallic sound. You can see it wobble a bit as well.
Mine fell off on the M1
Posted: Thu Oct 14, 2010 3:42 am |
Trade Rating: +23
my hdi's on 124k and running spot on best engine to come out of france
Posted: Thu Oct 14, 2010 3:54 am |
Mines on 105k and still going strong! only problems i've had with it are actually nothing to do with the engine!
