Latest: airmastertapes
Overall: 17133
Online Now [559]:
Visitors: 558
Today: 31336
Total: 106891928
Forums › The Car › 206 Talk › Where to fit air filter?
Go to page Previous  1, 2
Spanerman
PostPosted: Wed Oct 20, 2010 8:16 am Up
Road rallies and autotests my local autotest venue is often flooded and muddy
Got it all sorted now, need to make a cold air feed now
Hello
spud_owen
PostPosted: Wed Oct 20, 2010 8:19 am Up
Rob2859 wrote:
spud_owen wrote:
Rob2859 wrote:
the standard airbox will offer the most protection. check the intake pipe below the airbox to make sure there is not a rip in the fabric. as tis just foam inside that
is this directed at me? on mie the plastic was feck completely, hence why ive re fitted all now, the pipe ends up just behind the passenger head light, you would have to go through some serious deep water very slow to fill it i think!
no to sam. i still wouldn't trust it tbh.
ah cool sorry!!!! mines sound now, just follows the line of the normal one, just means no water can get in through the pipe!
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
PostPosted: Wed Oct 20, 2010 11:53 am Up
If the standard airbox and intake pipe are good enough for my car then I think it's fine for a XS! The standard set up is a cold air feed.
Spanerman
PostPosted: Wed Oct 20, 2010 12:02 pm Up
I found the problem
The bottom of the airbox was smashed up somehow? How odd.
Ill get a new one and try and get a side by side test on the dyno in uni
Sam.
Hello
Spanerman
PostPosted: Wed Oct 20, 2010 2:45 pm Up
Just did a timed 0-60 run with each filter.
Well 3 run with each, then averaged, the tanard box wa 0.2s quicker, not a maive amount but enough to leave it on.
Sam.
Hello
spud_owen
PostPosted: Thu Oct 21, 2010 6:46 am Up
thats a fair bit if your going to be doing auto tests etc, i doubt youll get out of second gear so alleration is what you need!
Brian
PostPosted: Thu Oct 21, 2010 7:37 am Up
Trade Rating: +31
Induction kits usually see increased in torque but not always increases in power!
PostPosted: Thu Oct 21, 2010 8:23 am Up
increase in torgue but not power? how come?
i though rev x torque = power?
spud_owen
PostPosted: Thu Oct 21, 2010 9:08 am Up
hence why you get better throttle respone then, although if they are not the right type for the car they can make both power and torque worse
Spanerman
PostPosted: Thu Oct 21, 2010 10:39 am Up
Right im doing some more tests today.
Im going to try the filter mounted on the TB direct, what should i do with the breather pipes? i can get a little filter on the head but what about the one on the rear?
Sam.
Hello
Rob2859
PostPosted: Thu Oct 21, 2010 10:52 am Up
just leave the pipe open its only to let gasses escape from. it just runs to the intake so the engine can burn them as its less harmful to the enviroment. however this is said to loose a bit of power. make sure the engine is up to temp too to take heatsoak into consideration.
Spanerman
PostPosted: Thu Oct 21, 2010 11:41 am Up
Yep engine will be at full operating temp
I have put some foam over both of them to let them breathe but to stop anything falling in, might try and get a dyno session booked in uni soon Smile
Hello
Page 2 of 2
