Online Now [283]:
Visitors: 282
Today: 56778
Total: 127952207
Forums › The Car › 206 Problems › Hit kerb, lost reverse on one side
Theden82
PostPosted: Sat Dec 18, 2010 12:52 pm Up
Hi, hope someone can help.
Just been out in the snow and unfortunately hit the kerb on the left side.
When I goto reverse the right hand side wheel goes round but the left doesn't. Followed by a straining motor sound. Driving forward tho is fine!
Any help or suggestions would be great!
macj
PostPosted: Sat Dec 18, 2010 12:54 pm Up
get it checked out in the daylight..... you broke or bent something
Spanerman
PostPosted: Sat Dec 18, 2010 1:06 pm Up
Are you on ice? The diff will send power to one wheel if it start to slip
Hello
Dabamash
PostPosted: Sat Dec 18, 2010 1:14 pm Up
Staff - Daba
Kern?
PostPosted: Sat Dec 18, 2010 1:28 pm Up
Does it drive forward?
Cr4zYb0y
PostPosted: Sat Dec 18, 2010 1:34 pm Up
Just been out in the snow and unfortunately hit the kern on the left side.
Wink
1.6 16v XSi Member #21
KILL COUNT: Twisted Evil
Pigeon IIIII
Dove I
Rat/Mouse I
Rabbit I
Hedgehog I
PostPosted: Sat Dec 18, 2010 1:43 pm Up
Wink
My bad Wink Thats my idea out of the window then...
darrenskinner1
PostPosted: Sat Dec 18, 2010 1:52 pm Up
this happend to me last winter, bent part of the axle. my wheel wouldnt turn at all, bent other things too cause it cost me just under £1000 to fix! good luck
Theden82
PostPosted: Sat Dec 18, 2010 2:17 pm Up
Sorry I meant kerb. Driving forward is fine. Can steer fine.
Just front left hand side wheel doesn't reverse. Begins to whine at biting point. Right hand moves fine.
Cr4zYb0y
PostPosted: Sat Dec 18, 2010 2:21 pm Up
I'd advise, you don't drive it at all. Just incase you make things worse.
Or something happens when your travelling at speed or main road etc.. For your saftey & anyone else's Smile
Pigeon IIIII
Dove I
Rat/Mouse I
Rabbit I
Hedgehog I
PostPosted: Sat Dec 18, 2010 3:09 pm Up
well there must be something got damaged in the left hand axle,i don't think it's a good idea to drive it,cuz make that will make things worse,specially in the transmission.
Lecktorious
PostPosted: Sat Dec 18, 2010 3:53 pm Up
Trade Rating: +59
Driveshaft?
'98 Nile Blue 306 GTi 6
giveitsomebar
PostPosted: Sat Dec 18, 2010 4:00 pm Up
might of broke something inside the diff
Theden82
PostPosted: Sat Dec 18, 2010 6:02 pm Up
Apologies but I don't know about motors. If it is something todo with the diff, what does that mean? And cost ?
Deceitful
PostPosted: Sat Dec 18, 2010 6:07 pm Up
look before you get carried away u want to do a basic check, get it up with a jack visual inspection and have a pull on the wheel, how hard did you hit the kurb?
Peugeot 206 Zest 1.1 5 door
