Online Now [62]:
Visitors: 61
Today: 1118
Total: 104974166
Forums › The Car › 206 Problems › Heater keeps running cold
Rob2859
PostPosted: Mon Dec 20, 2010 9:32 am Up
This is the second time now when I have gone to start my car in the cold and the heater refuses to run hot even when the engine gets to full temp. I was trying for 45 min to clear my screen this morning (frozen inside and out). I turned it off and started it many times when going in and out to get warm water and de-icer. I also tried fiddling with the nobs to see if the warm stuff would come out. Didn't go hot but when i came out of work a few hours later it was working fine.
Any ideas?
If I chop the plug off a hair dryer and wire it to my battery will it work as a temp fix?
Zoomy
PostPosted: Mon Dec 20, 2010 9:37 am Up
Rob2859 wrote:
...If I chop the plug off a hair dryer and wire it to my battery will it work as a temp fix?...
...does 220V AC and 12V DC ring a bell...??
Rolling Eyes
...You don't like my opinion? Wait until you hear the ones I keep to myself... Razz
namgaj
PostPosted: Mon Dec 20, 2010 9:40 am Up
Its 240V in the UK, but I know what you mean Razz
4.0 V8 S-Type Jaguar
Ste
PostPosted: Mon Dec 20, 2010 9:46 am Up
Staff - Ste
Used to be Wink it's now standardised to 230V +10% −6% As far as I'm aware..
The Cars:
Danny.
PostPosted: Mon Dec 20, 2010 10:07 am Up
All i know is dont plug a power supply from a pc when its switched onto 110v into a uk soccket Laughing
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
PostPosted: Mon Dec 20, 2010 10:09 am Up
They dont last very long Laughing
Can anyone else smell burning Laughing
Rob2859
PostPosted: Mon Dec 20, 2010 10:16 am Up
I didn't think about that Rolling On The Floor Laughing It just came to my head. Advice on my problem wouldn't go a miss tho Very Happy
macj
PostPosted: Mon Dec 20, 2010 10:37 am Up
Check your water level in header tank.... bleed the hoses at the heater for air locks..... get an engine cooling system flush.... alternatively... stick a garden hose up the heater pipes at the back of the engine with both hoses off... do both ways to make sure its not blocked.... remember to check antifreeze levels after
PostPosted: Mon Dec 20, 2010 10:39 am Up
NON biological washer powder / liquid / dish washer tablets added to the header tank are ideal for this Cool
It MUST be NON biological! ! !
Danny.
PostPosted: Mon Dec 20, 2010 10:40 am Up
Ive done that and the pc was sitting on my leg. Scared the jizz out of me.
Rob2859
PostPosted: Mon Dec 20, 2010 11:22 am Up
cheers macj. Do you think its down to a blockage rather than broken heater controls/bad connection then? Checked the water a few days ago and its got pleanty in it. Not sure why that would effect it. How does the heater bring in the hot air I am only familiar with how the cold intake work.
elcamino
PostPosted: Mon Dec 20, 2010 12:25 pm Up
Hot water goes to heater matrix makes a radiator warm.a fan behind this radiator blows the air.air gets warm when passed through then goes through ducts you select on heater panel.two lines from engine coolant system go to heater matrix.if upper one is as warm as the lower one(when engines warm)could be said heater matrix is ok. Smile
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
Rob2859
PostPosted: Tue Dec 21, 2010 9:36 am Up
I see now. Would have thought if the pipe is frozen then the engine would be overheating as well. I have about half a bottle of anti-freeze in it couldn't fit any more Very Happy
mjsroofing
PostPosted: Tue Dec 21, 2010 11:07 am Up
this is what i was going to say.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
mjsroofing
PostPosted: Tue Dec 21, 2010 11:08 am Up
you need to drain the rad and put a min of 2 litres mate
Mark
