Latest: Beduff1977
Overall: 17134
Online Now [3256]:
Visitors: 3255
Today: 192023
Total: 110356440
Forums › The Car › 206 Talk › Where would i find the ECU or the ECU number on my 206
Go to page Previous  1, 2
PostPosted: Wed Dec 29, 2010 9:05 am Up
russman wrote:
if i happened to get a ECU as long as it is for a 1.4i would it be ok for the 8v and the 16v to use the same one or would they have to be different ECU's?
Nope, you need the correct one for you engine, there's been plenty of different type ecu's used on the 1.4 so you MUST match the model numbers on the sticker!
Also a used / new / 2nd hand ecu will be locked because of the immobiliser, you would need to get it unlocked before it would allow you to start the engine.
Have you had your original ecu tested?
www.bba-reman.com/uk/index.aspx
chrisb1357
PostPosted: Mon Nov 05, 2012 7:43 am Up
Sorry to hijack this thread but i cannot work out how to remove my ECU on my 206. I have removed the front bolt but i cannot seem to get to the 2nd bolt at the back of the ECU to remove the tray as i want to check the ECU Earth
Chris
Chris
Page 2 of 2
