Latest: Stu-mill
Overall: 17131
Online Now [306]:
Visitors: 305
Today: 84991
Total: 104770538
Forums › The Car › 206 Problems › cooling fan sensor
cooling fan sensor
pudgie
PostPosted: Thu Aug 09, 2012 6:16 am Up
does anyone know where this is on a 1.4hdi as its not on the radiator and my fans don't cut in anymore Sad
my other cars a delica
PostPosted: Thu Aug 09, 2012 11:54 am Up
Bump if you're still here and want to know..
PostPosted: Thu Aug 09, 2012 12:11 pm Up
If it's like other 206's it uses the coolant temp sensor to tell the ECU the temperature. If it goes above a certain amount it switches the relays behind the front bumper to switch the fan on.
