Online Now [181]:
Visitors: 180
Today: 41974
Total: 127726934
Forums › The Car › 206 Problems › ECU?
ECU?
Go to page 1, 2, 3  Next
grantjohn1979
PostPosted: Fri Dec 31, 2010 7:02 am Up
hi guys found out i might need another ecu looked on ebay there's a company on there that sell them and states there unlocked and are ready to plug n play basically if you go on ebay n type peugeot 206 ecu there selling a couple for 180ish or with best offer?wanna actually know if i can just do this out with one in with the new so to speak?is it as straight forward as this?thanks grant
n/a
PostPosted: Fri Dec 31, 2010 7:04 am Up
Yes it will plug & play.
BUT
You will have NO immobiliser & your insurance company wont like that & may remove your theft cover from your policy.
Why dont you get your original one tested / repaired?
www.bba-reman.com/uk/index.aspx
johnk
PostPosted: Fri Dec 31, 2010 7:06 am Up
BUT
What He Said or if its beyond repair buy a locked one from ebay/scrappy for your car and bluestreak unlocked mine for £45.
Old info post count 1500
grantjohn1979
PostPosted: Fri Dec 31, 2010 7:07 am Up
could do that but its an aftermarket one so dont know if they would be able to fix it like an original peugeot ecu?
n/a
PostPosted: Fri Dec 31, 2010 7:10 am Up
Im very much doubting its an aftermarket ecu.
Any id numbers on the stickers? ? ?
grantjohn1979
PostPosted: Fri Dec 31, 2010 7:15 am Up
i was told by peugeot it was an aftermarket ecu after they said they couldnt read the ecu properly because of it being an aftermarket one
n/a
PostPosted: Fri Dec 31, 2010 8:01 am Up
Post up some pictures of the ecu then.
mjsroofing
PostPosted: Fri Dec 31, 2010 8:11 am Up
why do you need a new ecu????
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
grantjohn1979
PostPosted: Fri Dec 31, 2010 9:02 am Up
at a guess stalling sometimes slight mis fire hesitating picking up speed common ecu faults also on the ecu its hows the number 34177 will try n put a pic up of ecu
n/a
PostPosted: Fri Dec 31, 2010 9:07 am Up
if it's an after market ECU,then it's time to change it for the original Peugeot one from Scrapy,and unlock it as Johnk said :),and your car will be fine again Smile
grantjohn1979
PostPosted: Fri Dec 31, 2010 9:16 am Up
how can i upload phot of my ecu on here thanks guys
n/a
mjsroofing
PostPosted: Fri Dec 31, 2010 9:21 am Up
use photobucket mate
Mark
PostPosted: Fri Dec 31, 2010 9:22 am Up
Upload the photo to a free online photo hosting site like
photobucket.com/
Then copy & past the link in to your thread
grantjohn1979
n/a
grantjohn1979
PostPosted: Fri Dec 31, 2010 9:23 am Up
managed to work out photobucket heres my pic of my ecu hopes this helps guys n gurls thanks
n/a
Page 1 of 3
