Latest: S2cgm
Overall: 17178
Online Now [97]:
Visitors: 97
Today: 54022
Total: 137405131
Forums › The Car › 206 Talk › 180 spacesaver wheel
imjeeves
PostPosted: Tue Dec 07, 2010 2:14 pm Up
Is there a spare wheel that fits a 180? Does the gti spacesaver fit?
Antix
PostPosted: Tue Dec 07, 2010 2:18 pm Up
Custom - Red Stars
The 180 doesn't have a spare wheel cradle, are you planning on fitting one?
The spacesaver from a GTi 'should' fit, it wouldn't be a 16" spacesaver on a GTi so should fit a 17" alloy-shod car
imjeeves
PostPosted: Tue Dec 07, 2010 2:20 pm Up
No I need thin wheels to fit rally snow tyres. The real snow wheels are a fortune but if I could get a spacesaver that goes over the 180 brakes then i can use them
PostPosted: Tue Dec 07, 2010 2:24 pm Up
15inch you need, minimum
Antix
PostPosted: Tue Dec 07, 2010 2:25 pm Up
Custom - Red Stars
anything 15" or over will go over the brakes, if that helps Embarassed
Getting 4 of them might be more difficult though!
PostPosted: Wed Dec 08, 2010 2:48 am Up
I believe the space saver wheel won't fit over the front brake calipers...I've never tried it though so can't confirm whether it's true or not.
Lecktorious
PostPosted: Sun Jan 02, 2011 10:40 am Up
Trade Rating: +59
It's true, they won't clear the caliper.
15" full size steelie it is!
'98 Nile Blue 306 GTi 6
Rob2859
PostPosted: Fri Jan 07, 2011 12:01 pm Up
you will proberbly find steelies will be enough with standard tyres. Mine never gets stuck and can go up pretty steep snowy hills without getting stuck. To be fair how often does it actually snow.
imjeeves
PostPosted: Fri Jan 07, 2011 12:15 pm Up
It snows a lot in Scotland where the rally will be. Plus the stellies will still be too wide! Hmm will need to try find a spacesaver that fits off another type of car
EuroPeugeot
PostPosted: Fri Jan 07, 2011 2:56 pm Up
The 15" space saver DOES fit over the GTi 180 brakes. I did it myself about 6 months ago.
EDIT: I even had it over my 406 brembo calipers, with GTi 180 discs on.
100%!
