Latest: ArtistKS
Overall: 17145
Online Now [73]:
Visitors: 72
Today: 12296
Total: 116105493
Forums › The Car › 206 Problems › Need some help my car cuts out!!!!!
Markzedd
PostPosted: Thu Apr 05, 2012 12:30 pm Up
Hi, I've recently bought a 1.4 04 and we've just noticed that every so often it cuts out.... It's like someone has turned everything off, it only seems to happen when you come off the accelerator it doesn't do it whilst driving along.
Some times I can catch it before it cuts out, you can just hear the blowers stop working for a brief second. If it does cut out it starts perfect straight away...any help would be great..
gaffa786
PostPosted: Thu Apr 05, 2012 12:33 pm Up
check this
click here
Ash
PostPosted: Thu Apr 05, 2012 12:52 pm Up
Clean the ICV too.
PostPosted: Thu Apr 05, 2012 12:54 pm Up
Earth Strap.
Markzedd
PostPosted: Thu Apr 05, 2012 1:16 pm Up
Thanks for the quick response, where is the earth strap???
Hi,,,,,
Rob2859
PostPosted: Thu Apr 05, 2012 1:54 pm Up
Off the battery negative.
The wire may look fine but it doesn't matter. When you have that problem; use a jump lead (or make something suitable) to earth the battery negative. then try it. I found the manifold worked fine.
That will clarify your problem.
cmiic
PostPosted: Thu Apr 05, 2012 4:06 pm Up
if its only cutting out after an hour or tweo and it has an induction kit it may just be the induction kit, cheap shyt, i had that problem
Speed Matters!
