Online Now [171]:
Visitors: 170
Today: 28646
Total: 127713677
Forums › The Car › 206 Problems › Poorly 206 gti
Poorly 206 gti
Rina
PostPosted: Mon Jan 10, 2011 2:51 pm Up
Hi,
I've got a 206 gti 2002 and have had a "Catalytic convertor fault" and "anitpollution fault" coming up on and off for a year. It's been seviced and had both oxygen sensors changed. Now its coming up with that the" Engine coolant temp is too hot" but its not. Does anyone have any idea what else i can try, please. I don't know what else to try. Thank you
Rina
PostPosted: Mon Jan 10, 2011 2:54 pm Up
Is that the message that you got from a code scan or a message on the MFD?
gti180boy
PostPosted: Mon Jan 10, 2011 3:45 pm Up
As lee have said is that on code from a scanner or on your MFD
180 Doctor
Rina
PostPosted: Mon Jan 10, 2011 4:07 pm Up
The message is on the mfd, it went to peugeot and they said it just needed an oil change. But that didnt help.
Rina
PostPosted: Mon Jan 10, 2011 4:09 pm Up
Get it code read. Then post the fault codes back up here.
