Latest: tbafonso
Overall: 17130
Online Now [360]:
Visitors: 359
Today: 29856
Total: 104179851
Forums › The Car › 206 Problems › 206 gti 180 Brakes
206 gti 180 Brakes
nellyhaggis
PostPosted: Sat Jan 15, 2011 8:45 am Up
Hi All,
Has anyone experienced problems with there 206 gti 180 when they first start it up then go to brake?
My brake pedal was solid and the brakes did not want to stop me.
Its done it a couple of times and now my brakes dont feel 100%.
Any help would be great.
Cheers.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
dturbopeck
PostPosted: Sat Jan 15, 2011 3:06 pm Up
Sounds like you've got a brake servo fault, maybe a split pipe or the one way valve in that pipe is sticking, or it's the servo it's self!
PostPosted: Sat Jan 15, 2011 3:54 pm Up
What condition are the pads and discs, including rears. When was the brake fluid last changed? Should be every two years.
dturbopeck
PostPosted: Sun Jan 16, 2011 4:32 am Up
Steve206 wrote:
If it was a servo problem, then they would be soft. What condition are the pads and discs, including rears. When was the brake fluid last changed? Should be every two years.
If the servos not working the pedal goes hard! a good way of testing is to, pump up your brake pedal afew times, then hold pressure on, then start the engine, if pedal creeps down then your servo works.
PostPosted: Sun Jan 16, 2011 6:37 am Up
I really hope you ain't working on your own car's brakes, you have already given out 2 wrong pieces of wrong advice on this forum to do with braking systems Shocked
Lecktorious
PostPosted: Sun Jan 16, 2011 8:03 am Up
Trade Rating: +59
My brake pedal can be solid when using it first time, after that its normally fine!
Think I'm due a brake fluid change, that might help...
'98 Nile Blue 306 GTi 6
PostPosted: Sun Jan 16, 2011 1:55 pm Up
If you have a leak in your Master Cylinder, would they not go soft?
