Posted: Mon Jan 17, 2011 10:39 am |
Trade Rating: +28
Posted: Mon Jan 17, 2011 12:03 pm |
Just looks like a couple of them plastic clips hold it on
Posted: Mon Jan 17, 2011 12:33 pm |
They are basically plastic panels with a softer plastic edge. They're held on with those plastic clips that break all the time. The panels aren't there to seal against the glass.
Posted: Mon Jan 17, 2011 12:44 pm |
The water leak is in the passenger footwell isnt it? Have you run any wires through thw bulk head lately or disturbed the rubber grommet on the bulk head but under the carpet?
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Mon Jan 17, 2011 2:11 pm |
Trade Rating: +28
Cheers guys. Can you grab me the part numbers for those Lee and how many I'd need for both sides if possible please
Only one small cable going though the bulkhead and that isn't causing the leak as it's bone dry there.
Posted: Mon Jan 17, 2011 2:18 pm |
Left moulding 8120 F7 @ £23.09
Right moulding 8120 F8 @ £21.89
Clips 8565 40 @ 20p each
Posted: Mon Jan 17, 2011 2:20 pm |
Trade Rating: +28
Think I should be able to just get away with new clips? Rather not spend £22 if I don't need to haha.
Anyone also know where the water would drain to if it was to go down there?
Posted: Mon Jan 17, 2011 4:07 pm |
take it off, heatthat corner up and remold it to be the shape you want until it cools.
You can heat it in boiling water and use masking tape to hold it in place. When cool - refist and see if it needs asjustment. Repeat.
If it's rubber, it's worth a try - boiling a kettle is cheaper than replacement parts.
Posted: Mon Jan 17, 2011 5:18 pm |
Edward wrote: |
The panels aren't there to seal against the glass. |
Screen is bonded in, if you are sure the leak is coming in through the screen ask a windscreen fitter how many beer tokens it is to reseal the screen
Posted: Mon Jan 17, 2011 6:19 pm |
water leak could be the door membrane behind the door card
| GTi 180 - Scorpion Exhaust | |
