Online Now [309]:
Visitors: 308
Today: 64002
Total: 105957993
Forums › The Car › 206 Problems › rear wiper comes on when car unlocked
PostPosted: Fri Feb 04, 2011 9:36 am Up
got an 04 plate 1.4 hdi 206 the rear wiper seems to have a mind of its own and operates sometimes when the key is out and starts up when the car is unlocked in the mornings customer had to pull the fuse in the end any ideas what the cause could be??
also all the dashwarning lights glow dimly sometimes at night dont know if this is connected??
cheers
ukskater01
PostPosted: Fri Feb 04, 2011 11:09 am Up
Sounds like a faulty battery, not to sure to be honest
PostPosted: Fri Feb 04, 2011 11:18 am Up
It's sounding like a dying BSI.
Can you do a full diagnostic to see if any codes or errors come up?
Just check all the connectors into the BSI are secure., and softboot it back up.
PostPosted: Fri Feb 04, 2011 11:20 am Up
Brilliant posting Rolling Eyes
ukskater01
PostPosted: Fri Feb 04, 2011 11:44 am Up
At least I tried to help
Ash
PostPosted: Fri Feb 04, 2011 11:45 am Up
Yeh... but that was pointless on a level.
ukskater01
PostPosted: Fri Feb 04, 2011 12:24 pm Up
Well no one can be sure what's at fault unless you can actually check youself, my dash lit up dimmly when I had a flat battery
RGX_432
PostPosted: Fri Feb 04, 2011 12:52 pm Up
Common sense tells you that the dash will be very dim when there is low current coming through Wink
ukskater01
PostPosted: Fri Feb 04, 2011 3:03 pm Up
Yes which is one of the problems the op has
PostPosted: Sun Feb 06, 2011 12:57 pm Up
cheers lee Smile
yeah will run a scan on it when arrives at the workshop on tues just thought id post up on here see if anyone had any info
fingers crossed i can reboot it like you say and it will be ok Confused
