Latest: flipflap
Overall: 17140
Online Now [332]:
Visitors: 331
Today: 86848
Total: 113886708
Forums › The Car › 206 Problems › Squeaky Clutch
Squeaky Clutch
cahilg01
PostPosted: Mon Feb 07, 2011 6:04 am Up
I recently had my clutch replaced and ever since it has 'squeaked' every time I change gear. I've tried WD40 but no luck - any ideas?
Antknee
PostPosted: Mon Feb 07, 2011 6:07 am Up
I have the same problem with the squeakiness, sounds like there's a hamster under the pedal
Danny.
PostPosted: Mon Feb 07, 2011 6:48 am Up
Does the pedal squeek? or does it sound like the clutch..
If its the pedal i would use some 3 in 1 oil not WD40 as thats only meant to be a temp fix.
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
cahilg01
PostPosted: Mon Feb 07, 2011 7:03 am Up
Definitely the pedal. Where should I squirt the oil - and how much? (Simple explanation please!)
PostPosted: Mon Feb 07, 2011 7:07 am Up
Have a look under the pedal and follow it up. Smile Just wherever there is a new join/connection. Smile
cahilg01
PostPosted: Mon Feb 07, 2011 7:17 am Up
Ok - will try it - but if WD40 didn't work - will that? Thanks for the replies!
Danny.
PostPosted: Mon Feb 07, 2011 7:26 am Up
WD40 is not ment for permenant use.. where as 3-in-1 oil is.
gixxerkev
PostPosted: Mon Feb 07, 2011 7:44 am Up
Or use some motorbike chain lube spray, it worked fine on my brake pedal that squeaked, couldn't get the 3 in 1 can at the right angle to squirt the pivot point. Its also a "dry" lube so it wont attract dust/dirt which causes wear.!!!!!
An Ex '03 1.4 GLX driver, German technology all the way now.
