Latest: Beduff1977
Overall: 17134
Online Now [159]:
Visitors: 158
Today: 63125
Total: 108586330
Forums › The Car › 206 Problems › Lower arm problems.
Lower arm problems.
Davels
PostPosted: Fri Feb 11, 2011 6:39 am Up
My nearside lower arm was replaced nov last year due to me having a speradic knocking noise under the car a slowish speeds turning to the right over unevern ground. The car still handle perfectly and held the road as normal. Over the past month the car is making an indentical noise turning to the left so I'm thinking that the other side now needs doing, which isn't a problem. The problem I do have thos is that the car does feel as direct on the steering and a little like the tyres or overinflated. Can this be cause by the failing lower arm? As i said before there were no handling problems when the nearside went. Confused
MrZiggerz
PostPosted: Fri Feb 11, 2011 7:07 am Up
Maybe its more worn than the other side got? Not a mechanic but just a thought.
Davels
PostPosted: Fri Feb 11, 2011 9:16 am Up
Was my initial thought but the knocking is no where near as loud as the other side got before it was replaced.
