Posted: Sun Feb 13, 2011 5:18 am |
Is the 180 and the 138 the same?
| | ![](images/spacer.gif) |
| Peugeot 206 GTI 180.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere. | |
Posted: Sun Feb 13, 2011 5:20 am |
They will be as in taking it apart. But different size callipers, discs and the 180 will have better springs. Think everything else is the same. ![Smile Smile](images/smiles/icon_smile.gif)
Posted: Sun Feb 13, 2011 5:27 am |
So the 180 calipers will fit the 138 hub? MOT soon so needing one. Only one 180 hub on ebay and guys wanting £60 , can get a 138 assembly for £30.
Posted: Sun Feb 13, 2011 5:29 am |
I *think* so, but please wait for someone else to confirm this as I ain't 100% sure.
Posted: Sun Feb 13, 2011 5:36 am |
Just relised the one on ebay doesn't have ABS.
Posted: Sun Feb 13, 2011 6:04 am |
Thought ABS was on the driveshafts?
Posted: Sun Feb 13, 2011 6:18 am |
On the back of the hub.
Posted: Sun Feb 13, 2011 8:04 am |
Both GTi hubs are the same. 2.0 HDi hubs should be the same too.
