Latest: morgan20
Overall: 17135
Online Now [224]:
Visitors: 223
Today: 38542
Total: 110590673
Forums › The Car › 206 Problems › Clutch Cable
Clutch Cable
djoggie
PostPosted: Tue Jan 01, 2013 10:07 am Up
I cant put my gears in? its a new clutch last december but just need to adjust it. its not a hydrolic clutch but not sure how to adjust it?
any help or images would be great
cheers.
happy new year
bezford
PostPosted: Tue Jan 01, 2013 12:18 pm Up
Ive never done one but i think there's adjustment at both ends???not sure tho...but im sure you can make adjustment at the back of the clutch pedal...
R.HYDE
djoggie
PostPosted: Wed Jan 02, 2013 4:44 am Up
ive checked today but cannot find any adjustments? And Google isnt helping either!
Deckchair5
PostPosted: Thu Jan 03, 2013 3:18 am Up
Cable is self adjusting so if it isn't adjusting at all that you cannot even select gears then you need a new cable
djoggie
PostPosted: Thu Jan 03, 2013 5:04 am Up
how is it self adjusting? do i have to do anything to self adjust it?
Deckchair5
PostPosted: Thu Jan 03, 2013 7:19 am Up
It has an internal ratchet type system. There's nothing you can do to it when it's broken and the cable just slips through. Like your clutch, when it's worn out then it needs replacing
New cable is around £25 but follow the instructions EXACTLY and only release the spacer at the last operation after everything else is fitted otherwise the self ratcheting system ratchets up the slack and there's no going back
It's designed to be a one time fit and forget type operation and it's the best idea to renew the cable when you renew the clutch. The adjusting bolt by the clutch pedal is just to adjust the pedal height and that's all
