Posted: Sat Mar 19, 2011 5:53 am |
just intrested to see if it works well and doesn't flake off!, i want to do mine silver so i need plastic primer and paint and laquar, is that right?
Posted: Sat Mar 19, 2011 5:56 am |
and sand paper lol
Posted: Sat Mar 19, 2011 6:00 am |
| You never really learn to swear until you learn to drive | |
Posted: Sat Mar 19, 2011 6:37 am |
they turn up quite well if done right, i got my trims done about a month back and nothing negative so far
Posted: Sat Mar 19, 2011 9:04 am |
Trade Rating: +16
I did my door strips, front and rear bumper mouldings, front and rear windscreen covers and moulded arches last year using the guide ukskater01 suggests.
One bit of advice is prep, prep and more prep, doing it yourself is a pain in the a**e and takes ages, but the longer you spend getting each layer of each of the surfaces looking spot on... The greater the results..
Good luck mate.. you will be pleased with the results
Posted: Sat Mar 19, 2011 9:25 am |
yer did my side strips a few weeks ago using the guide and it turned out really well
Posted: Sat Mar 19, 2011 9:28 am |
Trade Rating: +23
s**te prep job = s**te finish - you can be the best painter in the world but if the prep's crap then the job will be crap
make sure you use a plastic primmer aswell
Posted: Sat Mar 19, 2011 10:32 am |
In answer to your question in your title, it will be a smaller list to find people who havent cc'd
