Latest: Puggingalong
Overall: 17129
Online Now [368]:
Visitors: 367
Today: 72810
Total: 101279952
Forums › The Car › 206 Talk › gti bottom engine mount
paulspug
PostPosted: Mon Apr 08, 2013 10:41 am Up
hi
just invested in a low milage gti 180, which is great, but I have a question.
Does the bottom engine mount on a gti 138 {02 plate} fit the gti 180 engine(04 plate}?
This is the engine mount which has the driveshaft go through it.
I thought that they were the same but am unsure.
Thanks in advance.
PostPosted: Mon Apr 08, 2013 11:30 am Up
The are both the same.
