Latest: tbafonso
Overall: 17130
Online Now [275]:
Visitors: 274
Today: 54248
Total: 102791213
Forums › The Car › 206 Problems › Warbling noise after cambelt change
Davels
PostPosted: Sat Mar 26, 2011 5:41 am Up
Hello peeps,
I've never driven a car after a cambelt change as i've always sold on before needing one. But i got my car fully serviced and the cambelt, tensioner and water pump changed this week. A little bit painful on the pocket especially on a car with only just 50k on the clock, but its more the age of the belt i was worried about.
Anyways I noticed that after the car has warmed up there is a "warbling" noise coming from the belt side of the engine. Now everything was brand new when fitted and there is no grinding or dry bearing type noises, just this odd noise when at idle.
Is this normal just after a change? as everything is settling and relaxing.
Or should i be taking it back pronto? The chap who did the work is probably the best mechanic i've ever met and he has been working on cars for over 50years and builds his own from the ground up. He also owned a 206 cc, a 206 GTi 180 and a 206 Gran T, while his wife still has a 207 cc. So i'm 100% in his work, trouble is he is away all weekend so cannot just pop back and get him to have a listen.
MrrNoName
PostPosted: Sat Mar 26, 2011 5:48 am Up
pretty sure thats not normal, tensioners maybe? take it back lol, everyone makes mistakes
Davels
PostPosted: Sat Mar 26, 2011 5:51 am Up
True, if it is a mistake it going to be unusual and one of very few made no doubt. It may even be a fault part or such like. Was really hoping it would be normal though Sad Laughing
MutilateTheDead
PostPosted: Sat Mar 26, 2011 7:03 am Up
I have the exact same problem after getting mine done last week, please keep us up to date on this as i want to know what it is too Smile
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
Davels
PostPosted: Sat Mar 26, 2011 2:04 pm Up
Right, he heard this noise too and it's not the cambelt. It's the aux belt where its has been disturbed and replaced. Where there are grooves in the belt and the old one went back on it's not sitting in the exact same position. He thinks it should settle but it i have any real concerns about it he said he pop a new one on to be sure. I'll see if he can do this next week and report back.
PostPosted: Sat Mar 26, 2011 2:22 pm Up
Its plain simple good engineering practice to also renew the aux belt when replacing the timing belt Rolling Eyes
Davels
PostPosted: Sat Mar 26, 2011 2:27 pm Up
I know, but he's the kinda of guy how will replace it if it's needed, the belt isn't even a year old. Partly my fault for telling him it was nearly new.
PostPosted: Sat Mar 26, 2011 2:40 pm Up
It was needed though Wink
Sounds like someone needs the hearing testing if they hand a car back with a warbling noise that wasnt there before they worked on it.
Davels
PostPosted: Sat Mar 26, 2011 2:41 pm Up
Fair point Wink
MutilateTheDead
PostPosted: Mon Mar 28, 2011 3:39 am Up
Cheers for update, i will get my aux belt sorted too then Smile
Davels
PostPosted: Mon Mar 28, 2011 7:00 am Up
Yeah it's going in tommorow for a definate fix so I'll let you know tommorow evening when I'm 100%
mrjonahlovetts
PostPosted: Mon Mar 28, 2011 10:15 am Up
have exactly same problem- have belt done 100 miles ago and its still making the noise
new aux belt for me too then. . .
mrjonahlovetts
Twincam007
PostPosted: Mon Mar 28, 2011 10:33 am Up
@Davels
Hello mate
Did you eventually manage to sort out the uneven/rough idling problems. What was causing it. I remember you changed almost all of the sensors on that motor?
Twincam007
Davels
PostPosted: Mon Mar 28, 2011 11:24 am Up
@Twincam007
I've just updated my main thread about the problem, it's now called ECU/engine misfire problem
SDK206
PostPosted: Thu Mar 31, 2011 3:46 pm Up
i've known a warbling noise to be an over-tensioned timing belt, not saying yours is but just incase the aux belt doesn't sort it Smile
If in doubt, drop a cog and put your foot down Smile
