Posted: Fri Apr 08, 2011 1:20 pm |
as does my 12yr old original bar! lol.
Posted: Fri Apr 08, 2011 1:38 pm |
So the anti roll bar bolt is missing, the plug in the centre of the end plate is missing and the washer hasn't been put into the groove either?
Which halfwit did that? Those washers sitting in the grooves are the only things stopping the trailing arms coming off the axle tube.
Posted: Fri Apr 08, 2011 1:59 pm |
I've lowered worse lol
Posted: Fri Apr 08, 2011 2:00 pm |
80brett wrote: |
I've lowered worse lol |
Worse than my car?
Posted: Fri Apr 08, 2011 2:03 pm |
The Titanic has less corrosion.
Posted: Fri Apr 08, 2011 2:06 pm |
Yeah mate a lot worse than yours lol
Posted: Fri Apr 08, 2011 2:31 pm |
Seabook wrote: |
did any disc axle use brake compensating valves? |
If the car has ABS, then no, and that includes drum axles.
Posted: Fri Apr 08, 2011 3:15 pm |
Steve206 wrote: |
Seabook wrote: |
If the car has ABS, then no, and that includes drum axles. |
ok, so that means i can fit one even the axle doesn't come with it?
Posted: Fri Apr 08, 2011 4:39 pm |
Seabook wrote: |
Steve206 wrote: |
Seabook wrote: |
ok, so that means i can fit one even the axle doesn't come with it? |
I have ABS and a brake compensator so i would double check with a garage. I think the newer cars which have ABS and EBFD might not have it. all depends on age IIRC.
(Don't quote me on it but i would check)
| 206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box, | |
Posted: Fri Apr 08, 2011 4:41 pm |
Coolspot wrote: |
Seabook wrote: |
Steve206 wrote: |
Seabook wrote: |
(Don't quote me on it but i would check) |
the thing is my car is old and don't have abs,ebc,ebd,abc...etc
so i will need a compensator valve on the new disc axle (as it is from a 05 gti, it doesn't come with that)
Posted: Fri Apr 08, 2011 5:04 pm |
The 1st picture you posted up shows the brake compensator attached. Also ABS was an option on the XS in 1999 and then standard in 2000.
But as i say the axle on the car shows you have a brake compensator spring but it may have been removed as i can't see clearly if its attached to anything.
Posted: Sat Apr 09, 2011 5:05 am |
Seabook wrote: |
Coolspot wrote: |
Seabook wrote: |
Steve206 wrote: |
Seabook wrote: |
so i will need a compensator valve on the new disc axle (as it is from a 05 gti, it doesn't come with that) |
Yeah its easy dude, you use the compensator valve that is on the car now, once you remove the drum axle you'll know what I am talking about.
If you need any help then drop me a pm
| Looking to buy my first peugeot 206 | |
Posted: Sat Apr 09, 2011 5:13 am |
l_jacka wrote: |
Seabook wrote: |
Coolspot wrote: |
Seabook wrote: |
Steve206 wrote: |
Seabook wrote: |
If you need any help then drop me a pm  |
ic, i just need to confirm that it will fit really.
that means one more stuff on the parts list
Posted: Sat Apr 09, 2011 5:27 am |
Yeah it will fit as they are all the same its just it you can get it off the old one otherwise yoir looking at about £60+ depending where you look.
Posted: Sat Apr 09, 2011 5:45 am |
Coolspot wrote: |
Yeah it will fit as they are all the same its just it you can get it off the old one otherwise yoir looking at about £60+ depending where you look. |
well, the old one seized every year so i might just have to think about that lol
