Latest: tbafonso
Overall: 17130
Online Now [66]:
Visitors: 65
Today: 22649
Total: 104212330
Forums › The Car › 206 Problems › Abnormal Tyre Wear
Abnormal Tyre Wear
AX-Rated
PostPosted: Mon Apr 11, 2011 3:13 pm Up
All this came about when the genius MOT testers decided to add 2+2 together and came up with 5.
Ever since I bought this car 2nd hand with only <40k on the clock, the back tyres have been suffering with inner edge abnormal tyre wear on the tread.
The above image shows a dark/light/dark/light pattern on the inner edge of the back tyres. These show the wear with around 1-2mm difference between the dark and light areas.
The mechanic/MOT tester assured me this was caused by the trailing arm bearings worn, which causes the tyre to oscaillate whilst driving, but months before this, I asked a ATS guy on the phenomenon and he assured me that this was just a attribute of all low profile tyres.
Unable to argue with the tester and a DVLA refusal in hand, I knew the bearings needed doing.
The tyres you see above are the Goodyear Eagle F1 GS-D2s (which are the recommended brand by Peugeot for the car as referred to in the handbook).
Seeing as the car has done low mileage and theyre fitted to the rear (which hardly wear), I assume these are the factory fitted units.
Since ownership, I've changed the fronts for Goodyear Eagle F1 GS-D3s as 2s cant be courced for love nor money.
I would put it down to the bearings as promised, but a keen eye to my misses SportKa confirmed my thoughts. Its just nothing to do with the bearings!
The same size of tyre, (be it a different make altogether) but the same tyre abnormality!
Anyone else suffer this problem with their original tyres!?
Black 03 GTi
PostPosted: Mon Apr 11, 2011 3:15 pm Up
get the tracking checked.
looks like knacked rear axle though
AX-Rated
PostPosted: Mon Apr 11, 2011 3:19 pm Up
Good suggestion, but the Ka doesnt have a rear axle.
Black 03 GTi
PostPosted: Mon Apr 11, 2011 3:21 pm Up
too much neg. camber. i presume you can adjust the camber on a Ka?
AX-Rated
And how do you adjust the tracking on a rear axle when it doesnt have adjustable tie rod ends!?
Black 03 GTi
M60SHW
PostPosted: Mon Apr 11, 2011 3:23 pm Up
could be but iv seen this on, new mondao's passats allsorts
PostPosted: Mon Apr 11, 2011 3:25 pm Up
are you talking about 206 or what?
on 206 no, you can't.
no idea what is a Ka.
first thing is get the tracking check, without knowing the camber, toe and caster no one whould know what is happening.
Nimminz
PostPosted: Mon Apr 11, 2011 3:29 pm Up
neither ka or 206 have tracking at the rear as neither steer from the rear. tracking more or less means steering.
2.0 8v RWD
SAB206
PostPosted: Mon Apr 11, 2011 3:30 pm Up
Nimminz wrote:
neitjer ka or 206 have tracking at the rear as neither steer from the rear. tracking more or less means steering.
:goodpost:
www.sab-graphics.com
I AM SYDLEXIC!
Nimminz
PostPosted: Mon Apr 11, 2011 3:45 pm Up
Check your tyre pressures to start with - its free
handbrake turns? lol
2.0 8v RWD
AX-Rated
PostPosted: Mon Apr 11, 2011 4:32 pm Up
Tyre pressures are fine, and despite a drop in pressure wouldnt cause some treads to wear and others not.
Black 03 GTi
AX-Rated
PostPosted: Mon Apr 11, 2011 4:40 pm Up
Ka alignment was checked months back and confirmed that was wildly out, only because of a front offside tyre worn on the inside and full tread on the outside.
I'm talking about both cars in this thread as they have the same problem YET have completely different syspension setups and different makes of tyres.
The rear Ka is shock and spring setup with a single wishbone and drum brake.
Thus proving it cant just be suspension wear/problem related.
The only similarity is the tyre size and profile.
Black 03 GTi
Davo_Pug
PostPosted: Mon Apr 11, 2011 4:55 pm Up
what about the same road/drive/lane you both drive on??
Davo_
Coolspot
PostPosted: Mon Apr 11, 2011 5:17 pm Up
Looks like my rear tyre tbh,
My axle has gone so bad that it it has 10mm camber at the top on the knackered side and a nice pattern like that on the tyre, You also get to see a lot of wobble going on on the slightest bump so she is off the road till pay day when i should be getting her sorted (Fingers crossed)
Could be the wheel bearing going in the hubs, as you say the suspension is different but the bearings would cause an identical problem.
Or could just be coincidence
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
benashley
PostPosted: Tue Apr 12, 2011 1:52 am Up
This is normally caused by worn rear shocks and Goodyears are prone to wearing like this, Because the wheel is bouncing it causes this uneven wear. There is no way you can adjust the rear tracking on either car and camber wouldn't cause the tyres to wear like that.
