Forums › The Car › 206 Problems › I think my car is dying :( |
Posted: Tue Apr 12, 2011 3:53 pm |
It's a long shot, but worth checking if all else fails.
We had a metro come in after bouncing off 2 kerbs, (near and off side) New subframes front and rear, new suspension parts where needed. Car went out and came back pulling. Suspension checked, no fault found. This went on for about 3 months. Car was laser jigged to check shell for straightness, laser aligned to check suspension. All was OK but car was still pulling badly. After lots of head scratching, it was found that the gears in the diff were damaged (no external damage) and due to the slight twist, was making the car pull. Diff replaced and no problem after that.
Posted: Wed Apr 13, 2011 5:51 am |
I will suggest these things to garage (although they should know!!!) thanks for the help guys
