Posted: Mon Mar 15, 2010 9:06 am |
Yeah but Hi Spec are at the lower end of the scale and they want £850 + vat, Wilwood don't do any for my fitment, so need custom fabrication...
Got to give Compbrake a ring next!
Posted: Mon Mar 15, 2010 9:10 am |
Surely you might aswell just buy some decent pads/discs instead of spending all the extra. Think sensible
Posted: Mon Mar 15, 2010 9:24 am |
f*** thinking sensible
Posted: Mon Mar 15, 2010 10:47 am |
Does anyone know if the GTi coolant hoses will fit the GTi180?
Ie I am looking at the Samco hoses but they only list for the GTi?
Also... If I were to get some nuts & studs to replace the wheel bolts what size would I be looking at?
pretty sure it's 1.25x??
Posted: Mon Mar 15, 2010 10:51 am |
| Jamie wrote: |
| F*** thinking sensible |
Good man. Sensible is boring
As for the brakes, couldn't you get some Brembo's in Pug Fitment (406 coupe or similar?) I know there's a couple of issues re spacers etc. Couldn't you have the calipers shaved a little to compensate? Maybe even some custom carriers or something?
Wilwoods are good, but you pay dearly for them!
| Daily Hack - 2013 Audi A3 Sport | |
Posted: Mon Mar 15, 2010 10:54 am |
You'd be surprised mate, Wilwoods aren't that expensive, they just don't make carriers to suit my car, so they wouldn't fit!
Posted: Mon Mar 15, 2010 11:53 am |
they will only fit if you buy a gti radiator aswell.
because the bottom house push's inside and click in on a gti180 and on gti they just hold on buy jubilee clip.
i have told you this jamie
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
Posted: Mon Mar 15, 2010 11:57 am |
| Jamie wrote: |
| Ape wrote: |
| Jamie wrote: |
But having a set of calipers with a name on them, that cost the better half of £1000 and are not needed thaaat much/not worth the money isnt exactly exciting
Wouldnt it be a better idea to see how the car does with some braided hoses, discs and pads.
Posted: Mon Mar 15, 2010 12:01 pm |
It's not so much the name though.
The 180 discs are 283mm, my LCR ones are just over 300mm iirc.
The single piston 180 calipers are nowhere near as good as the 4pot Brembo's that are on the LCR.
I know the disc's are a little bigger on the Leon, but its a bigger, heavier car as well. The braking power of the 4 pistons is much better than the 180 single pistons. Some LCR's don't have Brembo's either, and the difference between 4 pot and single pot is alot
Hmm, you said I might need a GTi radiator anyway didn't you Kyle?
Posted: Mon Mar 15, 2010 1:36 pm |
Posted: Mon Mar 15, 2010 1:38 pm |
| Jamie wrote: |
pretty sure it's 1.25x?? |
Same as the Venair hoses. I think you need to ask
Posted: Mon Mar 15, 2010 2:08 pm |
Wheel Studs should be 12x1.25 IIRC.
Dont go cheap on brakes, just pay the £100-150 to get the caliper brackets made up to mount something good like AP. Might want to buy a set with dust seals on the pistons too.
| 206 1400 8v HDi, Battle Bus - More Radical than Peugeot
In theory, there is no difference between theory and practice. In practice, there is. | |
Posted: Mon Mar 15, 2010 2:13 pm |
Dust seals are a definite
I'm not very clued up on brakes, so if I was going to go for Wilwoods, what exactly would I need, and how would I go about getting a bracket?!
Posted: Mon Mar 15, 2010 2:32 pm |
Also it seems that Compbrake offer a very good package for £750!
