Latest: S2cgm
Overall: 17178
Online Now [86]:
Visitors: 84
Bots: 2
Today: 38597
Total: 136965350
Forums › The Car › 206 Problems › 180 Squeaking Noise
180 Squeaking Noise
MissGTi180
PostPosted: Wed Apr 20, 2011 6:16 am Up
Me and another memeber on here (Ivor) have the same cars and we now also share the same problem...
When I start mine for a few seconds, maybe a few minutes I get a squeaking noise. Ivor gets his when the cars idle.
It sounds like a belt squeaking or something!?
Anyone know what that is as we haven't got a clue..ha!
Thanks Smile
www.facebook.com/mel206
smiddies
PostPosted: Wed Apr 20, 2011 6:18 am Up
It most probably is a belt!
Either Cambelt or the Aux belt! Whats your mileage? Have you had these changed recently?
MissGTi180
PostPosted: Wed Apr 20, 2011 6:19 am Up
I haven't had cambelt changed no, can't afford it at the moment.
Ivor only had his done recently though.
Whats an aux belt? Soz I'm not very good with engines lol Smile
smiddies
PostPosted: Wed Apr 20, 2011 6:24 am Up
Aux belt is also called an alternator belt, basically it charges the battery and stuff!! (Im not an expert)
The Squeaking noise could be a number of things... Water on the belt, incorrect tightness etc
best to have someone with some knowledge to have a look for you! If its due a cambelt change, dont hesitate to do it! Could lead to £1000's of damage rather then £100's!! Best to shop around for a better price! Change the water pump at the same time! And you could go and have a full service while your there!
MissGTi180
PostPosted: Wed Apr 20, 2011 6:27 am Up
Yeah its at the garage at the moment getting bodywork done i'll ask when I get it! Very true but this bodywork has cost me £800.00 and i haven't even found anywhere near that yet so wont be having anything else done to it anytime soon! thanks for advice Smile
-RAJ-
PostPosted: Wed Apr 20, 2011 6:36 am Up
for a test, take the aux belt off, start the car and if there is no squeak then you know its the aux belt and not the cambelt. thats wat i did
MrZiggerz
PostPosted: Wed Apr 20, 2011 7:31 am Up
clutch Surprised
MissGTi180
PostPosted: Wed Apr 20, 2011 10:21 am Up
clutch?
PostPosted: Wed Apr 20, 2011 10:27 am Up
Ancillary / Auxiliary / Drive / Fan belt - what ever you wanna call it - needs changing or tightening up.
Is it worse in damp/wet?
MissGTi180
PostPosted: Wed Apr 20, 2011 10:28 am Up
Yes! I think one day it was raining when I left work and it went on a bit longer than it usually does.
keeno
PostPosted: Sun Apr 24, 2011 11:23 am Up
sounds like im going to have to get someone to look at mine
Ivor.
206 Gti 180
206qa
PostPosted: Sun Apr 24, 2011 11:39 am Up
I had this problem on another car and sprayed some WD40 on the belt. This stopped it for a few seconds. Although not a fix it helped diagnose where the problem lay!
2006 1.4 Verve
3dr hatchback
