Latest: Stu-mill
Overall: 17131
Online Now [56]:
Visitors: 55
Today: 8004
Total: 104917644
Forums › The Car › 206 Problems › dented sill... :evil:
retta
PostPosted: Tue Apr 26, 2011 6:13 am Up
hi guys, I wondered if anyone would know whether it's possible to push out a dent that's on the bottom half of the sill of the car, under the passenger door, or whether filling it in/a side skirt are the only ways to repair it...
firedance 206 glx
PostPosted: Tue Apr 26, 2011 6:20 am Up
It can be pulled out. At worse you'd only need a tiny bit of filler & paint to make good.
PostPosted: Tue Apr 26, 2011 6:24 am Up
I agree!
drunknmunky
thanks for the heads up on this one as i have my passenger side sill dented inwards on the underside pretty badly and need it repaired but cant afford at the moment, may get a quote from the guy who is doin my car at the moment but good to know it can be repaired thanks Very Happy
techy
PostPosted: Tue Apr 26, 2011 6:28 am Up
a decent bodyshop will have a stud welder which welds little studs to the sill and then they will use a dent puller to pull the dent out, if they haven't got a stud welder a few tiny holes can be drilled and the dent puller screwed into these holes and then the holes will be mig welded up after the dents been pulled
will need a thin skim of filler after the dents been pulled but its alot better than just slapping loads of filler into the dent
retta
PostPosted: Tue Apr 26, 2011 6:30 am Up
ideal yep thanks for that guys, i will see what i can arrange, much appreciated Smile i know the feeling drunknmonkey - was worried i'd end up needing loads done to sort it out
firedance 206 glx
drunknmunky
PostPosted: Tue Apr 26, 2011 6:33 am Up
iv been putting off even getting a quote on it thinking it will cost me an arm and a leg Confused but with this info in hand i shall now be gettign a quote and hopefully getting it fixed sooner rather than later Very Happy
techy
PostPosted: Tue Apr 26, 2011 6:49 am Up
won't cost that much tbh
drunknmunky
PostPosted: Tue Apr 26, 2011 8:44 am Up
have you seen the size of the dent in mine Laughing its pretty big Sad
techy
PostPosted: Tue Apr 26, 2011 9:15 am Up
it could be full length of the sill and it still wouldn't cost that much
drunknmunky
PostPosted: Tue Apr 26, 2011 9:20 am Up
i will be finding out on thursday i think as its payday so if i can afford will get it fixed then Smile
stevedude
PostPosted: Tue Apr 26, 2011 10:48 am Up
i got quoted £1500 for all 3 pics, not including wing
tried someone else got quoted for main dent £270ish
Happydays
drunknmunky
PostPosted: Tue Apr 26, 2011 11:04 am Up
mines actually on the underside of the sill and about 1/4 of the width of the door but has pushed the sill right up
as said i will be getting a quote on thursday and will post up a picture and what i get quoted Smile
stevedude
PostPosted: Tue Apr 26, 2011 11:09 am Up
Cool
Happydays
techy
PostPosted: Tue Apr 26, 2011 11:29 am Up
thats far too much for whats needed
