Latest: Beduff1977
Overall: 17134
Online Now [1575]:
Visitors: 1574
Today: 119518
Total: 107779695
Forums › The Car › 206 Problems › rear axel 206
rear axel 206
moglie
PostPosted: Sun May 01, 2011 9:18 am Up
hi can anyone tell me how to tell the difference between a abs and non abs rear axel on a 206 ?..the axel im going to look at is already off the car pics would be great lol
hiya all newbie hear
PostPosted: Sun May 01, 2011 9:20 am Up
Does YOUR 206 have abs fitted?
Does YOUR 206 have a rear brake compensator valve bolted to the rear axle?
moglie
PostPosted: Sun May 01, 2011 9:24 am Up
just checked mine does not have a rear brake compensator valve fitted anywere on the axel
PostPosted: Sun May 01, 2011 9:25 am Up
Then your car should have ABS fitted then Wink
What year of 206 is it?
moglie
PostPosted: Sun May 01, 2011 9:28 am Up
mines a 52 2002 quicksilver 1.4 the car im getting the axel off is s reg 1.9tdi
PostPosted: Sun May 01, 2011 9:32 am Up
Peugeot never made a 1.9 tdi 206 Wink
S reg, good luck fitting that axle on, I doubt the replacement axle has abs sensors fitted & you also will need to loose the compensator valve.
It can fit BUT its gonna be more work then it could be if you had sourced the correct axle in the first place.
PostPosted: Sun May 01, 2011 10:08 am Up
S reg axle, 9 out of 10 the axle is in really bad shape.
moglie
PostPosted: Sun May 01, 2011 10:11 am Up
nope has no abs on the s reg axel ...just going to find 1 that does saves me some ball ache from the wife lol
PostPosted: Sun May 01, 2011 10:20 am Up
These people do a recon unit with a warranty
sspengineering.co.uk/
If your keeping the car for a while its a worthwhile investment Wink
You can either take the car to them & they will fit it.
OR
They will ship the axle to you & you sort your own fitting arangements out.
Fitting OR shipping is included in the price.
moglie
PostPosted: Sun May 01, 2011 10:29 am Up
im not keeping the car for long just till end of the year then looking for a new 1 just need it to be safe as i got my kids in it at weekend ...me dads doing his nut as i keep nicking his lol
PostPosted: Sun May 01, 2011 10:38 am Up
How badly damaged is your beam?
You can replace the bearings cheap enough if the rest of the beam is in good condition.
moglie
PostPosted: Sun May 01, 2011 10:41 am Up
the back wheel is moving from what we can see its not the wheel its the axel thats got play in it ...plus it bangs like a good un when going over speed bumps or pot holes
PostPosted: Sun May 01, 2011 10:44 am Up
i woonder how much a garage would charge to do the bearing.
considering most garage don't touch the torsion bar Laughing
